  • Replies 61
This game does look pretty sweet. I haven't played the first one, would anyone recommend playing the first one or just go straight onto this?
the frist one was all about the story line
definatley play the first one so the story makes sense!
  • 3 weeks later...
I'm all pre-ordered, and uncapped in 2 days :(
Ordered via UK or US as well (over steam), can't beat $44 :)
not a bad price at all.. :)
http://www.smh.com.au/digital-life/games/r...00208-nluu.html
Cannot wait for this game :D Will pick it up tomorrow...... will probably have 20 minutes to check it out and then time for 3 weeks :(
played it for about 30 minutes.. kinda different kind of the same. Havent gotten very far in to yet obviously though, so there isn't much your character can do, played multiplayer for a about 15 minutes, pretty cool - but again, havent played it enough to really comment. Hopefully I can play it a little more before I fly to the states on Friday, otherwise it will have to wait until the end of the month before I get to play it any more :banana:
i got the game, a vinyl record with the song from the original game on it, a CD with music from this game, a book of the artwork from the game, and 3 small posters. the posters are advertisements that you see for plasmids and stuff from the game, I havent unrolled them though so not sure which ones, probably the same ones they gave away with the viral advertising they did last septemeber. . unfortunately you don't get the wine bottle though :D oh and 2 extra character unlock codes for the multiplayer..
pretty sure it's going to be a great game, I am just happy to be back in Rapture :( lol
I'm gunna sort it out now... do you just go to the US site, login, put in credit card details and lie about the address making it US?
gimme some answers puhlease!
ph yeah slim, can I has record for wicky wicky? :)
you gotta change your address i think?
Not sure, just google it.
If not, let me know later and ill ask my bro to post up how
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
