  • Replies 61
PC BioShock 2 Widescreen & Gamepad Issues
[12:53 pm ET] - Share - 44 Comments
The 2K Forums have a thread complaining that widescreen support in the PC edition of BioShock 2 does not work properly, as it displays a cropped version of the 4:3 screen, rather than true widescreen depiction of the scene (thanks Gamer's Hell). This is pretty surprising, considering the original BioShock suffered the same problem until a patch came out several months after the game's release. One post by 2K Elizabeth acknowledges the problem, saying it is restricted to the PC edition, while a later post says a fix is on the way: "I am compiling a complete list with a nifty screenshot for you, but in short: Yes, there's a problem, yes, a fix is on the way, yes the view will expand horizontally for you widescreen gamers. I wanted to let you know as soon as I could - so stay tuned for the details."
what dumbasses, the community ripped them a new one the first time this happened now they've gone and done the same shit agian
'you widescreen gamers'...
who the f**k doesn't have a widescreen these days?? besides these programmers...
I don't... I have 50inch epicness!!!
lol but seriously, who cares if it doesnt come out in widescreen straight up... the fact that they made a quality game instead of the mass produced crap by EA (buy everyone) should be bowed to... I mean they patched it for widescreen last time, they can do it again
It'll only take 30mins to download if you have faster internet...
Fail if you don't :P
I can only get ADSL 1 in my area, stupid mount Hawthrown exchange must still be running on dinosaur age technoloy...
Game is still being downloaded... :)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
