Not having much luck selling my car complete so looking at striping it down and selling some parts if I can get the right $$ and then I will keep the shell and build it up later. I will post up as much info as I can but I am still trying to find all my stuff as the car engine etc was built about 4 years ago and I cant remeber it all.
Whole car is for sale other section, asking 20k, if I can get serious buyers for some stuff here I will start stripping car down. For now will try and keep chassis so I can rebuild it later. Wont to get a Stagea for now as the kids can ride around it that a lot easier.
Engine: R33 RB25,2630cc?, fully built engine by Nisspeed here in Adelaide. Engine was built, engine dyno tuned and fitted in car, we used it for 12 months at about 4 drag meets and very little street use. Engine was stipped down to check it out and have a look, sump baffels were istalled, new rings and since then it has only just been started. Engine includes
RB26 crank balanced, streightened and ground
RB26 rods preped with ARP bolts
ARP cradle studs
Wiesco forged 87mm pistons
sump mods for anti oil surge
Metal head gasket
N1 oil/water pump
New thermostat
RB25 head ported
HD valve springs
HKS? 272 and 264 cams ( one was new the other as good as cant remember the exact specs)
HKS adjustable exh cam gear
ARP head studs
RB26 clear cover - modified
R33 CAS
Rocker covers painted gloss balck with -10 fittings for the breather pipes
engine does not include inlet/exh manifold/PS pump/alternator/
Price: $6000
Turbo Setup
Garret GT3040, 0.82 exh housing
Blitz? Stainless low mount manifold - this thing is a work of art, I got it SH but in exc condition and modified the flanges to suit
Tial 38mm external gate
Will also include 3.5" dump pipe off turbo and screamer pipe off wastegate, as well as oil drain pipe for turbo, braided oil and water feed lines for the kit
Turbo and gate were new and are still in as new condition
$2000
Inlet:
Custom inlet manifold on std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1200
Fuel System
SX fuel pump, good for 700 HP
SX fuel filter
Alloy surge tank with pump and filter mounted on plate
Fuel cell about 30 ltr and lift pump
all conected with stainless braided teflon lines, all parts purchased new
$700
ARE cooler, 600x300x100 Bar and plate, 2.5" inlet, 3" outler,
anyone that knows ARE stuff know it is top quality, with cast end tanks for optimum flow etc, barely a mark on the cooler
$800
ARE 40mm radiator, duel pass cross flow, fits my 32, not sure if 33 etc are the same, includes large themo fan (15" ?)
$600
R33 RB25 gearbox, good contition still shifts smooth as, includes slave cyl
$1000
OS tripple plate clutch, clutch was used but I put new plates through it, includes flywheel, pressure plate, etc
$500
Conversion kit to put R33 box in R32 includes modified 1 piece tail shaft, modified gearbox mount
$100
Also have cooler piping in 2.5" and 3'' stainless, painted silver with tial BOV, and inlet pipe, 4" with big K&N filter can can include some of this if you buy multiple parts.
Motec M800 ECU, with custom wiring loom for the engine, AEM CDI unit, Bosch external coils and leads, Motec has wide band lambda enabled and comes wilth all sensors, looms, plugs etc. This will do almost anything you require of it on any engine. $4500
AIM Pista data logger/dash, this unit replaces all your gauges in the car, full graphic displace and interfaces with ecu via Can bus. Does lap times/track mapping, shift light warnings etc. Comes with lap timer, speed senor, 2 x temp probes and everything else you need see http://www.aimsportsystems.com.au/mxl_system.html
$1700
Blitz Duel SBC spec R boost controller, as new, $500
All parts are still in car so only have these photos.
Prices listed are fairly firm, and for those that have done these mods will know they are probably at least half of what it costs to get done.
Dyno sheet attached of what the car did on the roller at about 1.4 bar boost
Please contact me by email [email protected]
Have interest in just the exhaust manifold, so if you wont just the turbo may seperate.
Also willing to trade for a stockish RB20/25 set up just so the thing can get moving if this stuff sells
Yeah, thats the starting cost for the unit, then add your looms, sensors, upgrades. The cost inlcludes the CDI unit, coils and all looms are made to suit your Std RB20-25-26. Includes the wideband lamda upgrade so you can monitor your AFR accurately and log them.
May go a little lower but it is not one of the parts I especially wont to sell as I know it will do anything that I require of it in the future and the replacement cost will be a lot more than I will get for it.
are you flexable on the motec?
Trade they are under 3 grand to buy the unit.
Will do Built RB25/26 engine for 5k
Motec M800 looms CDI and all the senrsors coild etc for 4k
Will include tailshaft etc with gearbox if someone needs it for a conversion
Aim Dash, $1500
Will do deal if someone wonts multiply parts and willing to look at swaping stock engine setup, thanks
interested in clutch depending how much meat is left on it mate
Had somone else interested in clutch, if he does not reply in the next day will let you know, clutch had new plates put through it and has done little work since so will be 90% plus on them, thanks
