Yeah manual box, is supposed to be sold just waiting for payment etc, if not will let you know, freight would probably be about 100 up there
Hey mate are we looking at a manual box? if so very interested, btw ne idea on shipping to brissy?
Please see below for what is still avalaible
Engine: R33 RB25,2630cc?, fully built engine by Nisspeed here in Adelaide. Engine was built, engine dyno tuned and fitted in car, we used it for 12 months at about 4 drag meets and very little street use. Engine was stipped down to check it out and have a look, sump baffels were istalled, new rings and since then it has only just been started. Engine includes
RB26 crank balanced, streightened and ground
RB26 rods preped with ARP bolts
ARP cradle studs
Wiesco forged 87mm pistons
sump mods for anti oil surge
Metal head gasket
N1 oil/water pump
New thermostat
RB25 head ported
HD valve springs
HKS? 272 and 264 cams ( one was new the other as good as cant remember the exact specs)
HKS adjustable exh cam gear
ARP head studs
RB26 clear cover - modified
R33 CAS
Rocker covers painted gloss balck with -10 fittings for the breather pipes
engine does not include inlet/exh manifold/PS pump/alternator/
Price: $6000 - now 5k
Inlet:
Custom inlet manifold on std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1200
Fuel System
SX fuel pump, good for 700 HP
SX fuel filter
Alloy surge tank with pump and filter mounted on plate
Fuel cell about 30 ltr and lift pump
all conected with stainless braided teflon lines, all parts purchased new
$700 most likely sold
ARE cooler, 600x300x100 Bar and plate, 2.5" inlet, 3" outler,
anyone that knows ARE stuff know it is top quality, with cast end tanks for optimum flow etc, barely a mark on the cooler
$800
ARE 40mm radiator, duel pass cross flow, fits my 32, not sure if 33 etc are the same, includes large themo fan (15" ?)
$600
Also have cooler piping in 2.5" and 3'' stainless, painted silver with tial BOV, and inlet pipe, 4" with big K&N filter can can include some of this if you buy multiple parts.
Motec M800 ECU, with custom wiring loom for the engine, AEM CDI unit, Bosch external coils and leads, Motec has wide band lambda enabled and comes wilth all sensors, looms, plugs etc. This will do almost anything you require of it on any engine. $4500 M800 most likely sold - CDI coils avaliable if so
AIM Pista data logger/dash, this unit replaces all your gauges in the car, full graphic displace and interfaces with ecu via Can bus. Does lap times/track mapping, shift light warnings etc. Comes with lap timer, speed senor, 2 x temp probes and everything else you need see http://www.aimsportsystems.com.au/mxl_system.html
$1700 - most likely sold -
Blitz Duel SBC spec R boost controller, as new, $500
All parts are still in car so only have these photos.
Prices listed are fairly firm, and for those that have done these mods will know they are probably at least half of what it costs to get done.
Dyno sheet attached of what the car did on the roller at about 1.4 bar boost
Please contact me by email cahrns@ahe.org.au
Sorry decided to keep that stuff and the box so I can get the car running again soon.
The 32 mount only needs a couple of plates to make it work and you need to get a 32 GTR speed sensor and change the gear on the end from memory
Do you still have the tail shaft and gearbox mount for R33 gearbox into R32?
Did you also have the set up for the speedo drive?
  • 4 months later...
  • 1 month later...
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
