Yeah manual box, is supposed to be sold just waiting for payment etc, if not will let you know, freight would probably be about 100 up there
Hey mate are we looking at a manual box? if so very interested, btw ne idea on shipping to brissy?
Please see below for what is still avalaible
Engine: R33 RB25,2630cc?, fully built engine by Nisspeed here in Adelaide. Engine was built, engine dyno tuned and fitted in car, we used it for 12 months at about 4 drag meets and very little street use. Engine was stipped down to check it out and have a look, sump baffels were istalled, new rings and since then it has only just been started. Engine includes
RB26 crank balanced, streightened and ground
RB26 rods preped with ARP bolts
ARP cradle studs
Wiesco forged 87mm pistons
sump mods for anti oil surge
Metal head gasket
N1 oil/water pump
New thermostat
RB25 head ported
HD valve springs
HKS? 272 and 264 cams ( one was new the other as good as cant remember the exact specs)
HKS adjustable exh cam gear
ARP head studs
RB26 clear cover - modified
R33 CAS
Rocker covers painted gloss balck with -10 fittings for the breather pipes
engine does not include inlet/exh manifold/PS pump/alternator/
Price: $6000 - now 5k
Inlet:
Custom inlet manifold on std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1200
Fuel System
SX fuel pump, good for 700 HP
SX fuel filter
Alloy surge tank with pump and filter mounted on plate
Fuel cell about 30 ltr and lift pump
all conected with stainless braided teflon lines, all parts purchased new
$700 most likely sold
ARE cooler, 600x300x100 Bar and plate, 2.5" inlet, 3" outler,
anyone that knows ARE stuff know it is top quality, with cast end tanks for optimum flow etc, barely a mark on the cooler
$800
ARE 40mm radiator, duel pass cross flow, fits my 32, not sure if 33 etc are the same, includes large themo fan (15" ?)
$600
Also have cooler piping in 2.5" and 3'' stainless, painted silver with tial BOV, and inlet pipe, 4" with big K&N filter can can include some of this if you buy multiple parts.
Motec M800 ECU, with custom wiring loom for the engine, AEM CDI unit, Bosch external coils and leads, Motec has wide band lambda enabled and comes wilth all sensors, looms, plugs etc. This will do almost anything you require of it on any engine. $4500 M800 most likely sold - CDI coils avaliable if so
AIM Pista data logger/dash, this unit replaces all your gauges in the car, full graphic displace and interfaces with ecu via Can bus. Does lap times/track mapping, shift light warnings etc. Comes with lap timer, speed senor, 2 x temp probes and everything else you need see http://www.aimsportsystems.com.au/mxl_system.html
$1700 - most likely sold -
Blitz Duel SBC spec R boost controller, as new, $500
All parts are still in car so only have these photos.
Prices listed are fairly firm, and for those that have done these mods will know they are probably at least half of what it costs to get done.
Dyno sheet attached of what the car did on the roller at about 1.4 bar boost
Please contact me by email [email protected]
Sorry decided to keep that stuff and the box so I can get the car running again soon.
The 32 mount only needs a couple of plates to make it work and you need to get a 32 GTR speed sensor and change the gear on the end from memory
Do you still have the tail shaft and gearbox mount for R33 gearbox into R32?
Did you also have the set up for the speedo drive?
  • 4 months later...
  • 1 month later...
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
