you should always run a spring to the target boost as close as possible
ie using a 10psi or 12psi spring and trying to run 18psi-20psi is going to be impossible to control for any good electronic unit
so my advice is to simply fit a better spring, go as close as possible to the target
until you sort out the mechanical spring side no electronic controller will work correctly
  • Replies 79
Yeah I have asked a couple of times in this thread if anyone can point me to a supplier of reasonable priced actuators suited to the application - so far in NZ the cheapest I have found for one is ~$470NZ which is far too much for me at this stage.
The actuator/AVCR can hold 15psi or 17psi flat once it reaches it so I can't see any reason why it should be technically impossible to make it reach it quicker when the engine is clearly capable of doing so... I will post results of how Mondays experiment goes when I do it, seems no one seems to have tried it.
I think somehow we are forgetting what an actuator does? An actuator does not snap open @ 'x' preset boost level, If an actuator is rated @ say 8psi then it will be fully open @ 8psi however it will gradually open up from much lower pressure. The whole idea of an actuator is to create a linear onset of power. Simply increasing the the preload will increase the boost rating of the actuator not necessarily help with response...
The only way to fix the problem and have ALL your boost hold until 'x' desired level is to fit a good mechanical one way pneumatic valve before the actuator or use an EBC (which is basically the latter but with other fancy crap added to it and in cabin control...)
If you soley rely on the actuator you will never have your turbo's true response potential, however you will have a much smoother increase in power and provide your driveline with less hassle. Depends what you want.
One of the reasons threads like this can go in circles, or seem like people are missing things is when people don't read the original posters posts clearly - you obviously missed the 800x600 image of the Apexi AVC-R EBC I have been using to fight this issue :( I have been almost tempted to get a ball valve to put on the feed to the AVC-R/actuator... though I really don't think I should have to consider that.
I agree i should not have placed EBC in there. Some do a good job and some do not.
My post is edited and imo that's the best way, unless you get an EBC that monitors boost in a similar way. With a pneumatic valve in place it cannot let any noticeable amount of pressure through to the actuator until it hits the set level then your away, which gives you no loss of boost untill you want it.
Then you can keep your current actuator too as it really does not matter.
PS; your right though, i never even read the first post only a couple of responses on the last page when i clicked reply... There is only so many fixes to these problems.
Edited by GT-RZ
I use and recommend the Jaycar boost controller. It uses a solenoid (actually I used the stock R33 solenoid but any normally closed one will do) to regulate boost to the actuator (i.e. it is not a bleed type controller). It uses a signal from the injectors to regulate the solenoid and the realtionship between the duty cycle of the injector and the duty cycle of the solenoid is determined by a controller which is entirely user adjustable. I believe this method of control is unique to the Jaycar although someone may correct me if they know of another. With this system NO BOOST AT ALL gets to the actuator (apparently unlike your AVCR) until you want it to. With my ball bearing GCG highflow turbo boost build is really rapid to my max of 1 bar (about 16psi which I have chosen as the max because i have stock internals) and it can hold it for as long as the turbo can make it. I will soon have a dyno chart where i can show the boost curve (well more of a flat line with a short steep approach and some tailing off at the top). the only catch is the Jaycar has to be assembled although you could possibly get someone to build it for you ( I had to) but the kit for the unit and the hand controller come to about $150. If you are interested send me an email to [email protected] and I will send some information as an attachment although there is a 50 page thread here:
http://www.skylinesaustralia.com/forums/Ja...tro-t61207.html
That link doesn't work for me .
Sydneykid had a lengthy string in the Stagea section about that Jaycar Independent Boost Controller Kit and the Hand Controller kit used to programme it .
Was very impressed from memory , actually didn't he have it referenced off MAF meter signal voltage ?
Cheers A .
Edit , "Jaycar boost and fuel control" - that's Sk's thread in SAU .
Can someone post the link , stupid computer playing up .
Edited by discopotato03
Haha not sure if you are joking or not - but just in case, I was free boosting. I backed off when boost hit 1.1bar - not when it stopped climbing. It was climbing FAST, and if I didn't lift off it would have kept going until something else stopped it :(
It was just a test to see if it will spool well if the wastegate doesn't open prematurely, and it does.
Fastrotor - Not sure quite what you meant, do you understand how an electronic boost controller controls a dual port/external wastegate? I'm a little tired, so could just be failing at reading you right.
The dual port actuator has two sides, one is the "compressor" feed which is just a line from a boost source - same as any other turbo setup without a boost controller. The other goes to a second port on the wastegate, which is used by electronic boost controllers to regulate boost. What they do in this case is let boost into that side of the wastegate to effectively beef up the actuators resistance to opening by pushing the wastegate closed - when the target boost level is reached the boost controller stops pushing boost into this side of the actuator and the the "normal" spring tension collapses to the original boost feed and wastegate opens.
What I did to prove the actuator would allow this to happen is just put the boost feed into both sides of the actuator, to ensure that it stayed shut- just in case somehow it could creep open... which would be possibly caused by a leak or restriction on the boost controller line.
If I am answering the right thing, does that make sense?
Ah, i misunderstood, thought it was setup to bypass the solenoid like many of us do on stock rb25's...
I have replaced the Jaycar link with one that works. Yes it was another SK project but no the Jaycar boost controller has only 4 connections: power supply, earth, signal from any injector and output to solenoid. You may be think of one of SK's other projects - DFA, tech edge etc.
Yeah sorry I was a little short, posted on a few forums and had a head of people telling me to do things I had already tried and mentioned haha. Fingers crossed that trick does something useful, if it is it could be handy for others looking at similar solutions. I will post the result either way when I get the valve :)
I have a pressure releif valve set at 11 psi, then the air goes from there too my good old turbosmart boost controller(single stage!). I have a 9psi spring and I can (within reason) change the way the boost comes on.
Currently the setup is easily holding 16psi on a 45mm external gate.
I can have the valve shut until any preset value I dial in, I can even make a boost spike if wanted.. and the whole system cost less than $100 fitted! Never had a single issue with it.. and its been like that on 3 different cars and hasn't stopped in the last 9 years!
its so basic to look at, but it does an awesome job and I dont think that I'm ever going to change it!
The GCG turbos come with a better actuator IIRC - hence you wont be having as noticeable problems. You'll be lucky to be moving 2-3 psi from memory
purchase for general and their specifically made hi-flow could be different actuators in terms of supply.
being one is generic garrett, one is a setup they package themselves inhouse etc etc.
its just speculation, but i just remember someone posting something about the GCG hi-flow turbos having different actuators to vanilla purchases, which would make sense
I had some fun during a gap in the weather today, so here is the new pressure relief valve I got from Norgren:
I took advantage of the opportunity of doing these changes under the supervision of Tomei:
I did my first tests with the twin port wastegate as I need to remodify the setup to suit the old wastegate (changes were needed for the twin port) as my relief valve is best suited to a single port actuator... and the dual port actuator seems to be rated to 7psi vs my old actuator's 12psi. As a result of this I had some boost level oscillation, but that was no surprise.
My flatmate is going to reweld up my old actuator setup so I can re-install that - and going by tonights testing I suspect its going to finally have the type of boost control I have been hoping for:
I was a little weary of it potentially boost spiking, but no issue with that at all - with the soft spring it hits 1bar and drops back a couple psi and then rebuilds it in reducing swings but I expect the harder spring and a bit of tuning to sort it out.
My crappy Garrett actuator came inside a Garrett turbo box all packaged up OEM like.
480009-0009 or as some call it GAR480009-0009 or GRT rated at 1bar.
As listed on ATP's website
They are just a lazy actuator unfortunately. Hindsight as they say.
Most go the large can actuators if you want decent boost control out of an IW.
18psi Large Can (not available in AUS I believe as I couldn't find one)
MTQ have the 14psi version. Identical and is near impossible to lift off its seat and important for IW's has a LOT of travel unlike the crappy Garrett item.
Either that or I guess try a non-Garrett 1bar actuator.
As for twin port IW actuators I was told to steer clear of them. :thumbsup:
Edited by SLAPS
Yep, just went for a thrash and I really need a passenger to help me keep an eye on it - it builds boost good and quick but I can't tell if it holds flat or not :rolleyes: Its a bit too quick to safely watch that, and it feels good but I don't think its quite perfect yet. I need a passenger to keep an eye on or film things.
ever tried a profec b? i have the same turbo using a 12psi actuator (all mtq had in stock at the time) and i've held up to 21psi perfectly. can set the boost the soldenoid starts letting boost to the actuator.
1. sell avc-r
2. buy profec
3. profit :down:
Well I got someone to drive the car for me and take vid, I have been trying to set it up to target ~1.1bar - so far the tune we have got in there is very conservative, basically so I can suss boost control out enough that a dyno session would be justified without popping the motor so its not going to be
making the best use of the air its getting at the moment. Either way, this should give a rough idea of the spool now I've had a tinker with the AVC-R and boost relief valve.
I have a mate driving, basically gave it a stomp from around 2900rpm in second which was where it was previously at its worst: http://www.youtube.com/watch?v=-AYS8ixmMPY
I suppose I should add as I don't know what other peoples .82a/r GT3076Rs are like on their RB25s - but this is much much better than I was getting before, and my mate wasn't giving it 100% throttle (don't know if or how much difference that'd make). It isn't PERFECT but I consider the boost relief valve experiment a success, considering the money spent vs. gains had. If there is a better solution for the same or less money, I am still keen to hear but this is definitely keeping me a fair bit happier.
Edited by Lithium
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
