hey guys
i have recently replaced my coils and was driving for bout 2 months and my car started missfiring again
and engine light come on.
i checked the fault and it was fault 21 wen i replaced the coils it missfired every now and then then stoped completely for bout 2 month and now its starting to come back on.
my question is could it be my plugs or something else. i want to get it running properly so i can sell it as i need a bigger car cos i have a two week old little girl now and the 34 is to small lol
any help is much appreciated
thanks
https://www.sau.com.au/forums/topic/283152-need-help/
when was the last time you changed the plugs? if it's been a while I'd get those changed first as it's a cheap and quick fix. If it's misfiring on idle / low rpm, try a higher gap ... my 34 would constantly misfire on the copper NGK's on gaps smaller than 1mm (but just on idle and upto 3000rpm)
Get the NGK coppers ..heatrange 7 and try a .9 or 1mm gap, if that doesn't fix it search for "misfire" and see what else it could be. Chances are it's just the spark plugs.
If you're not mechanically inclined, take it to Unigroup in Girrwaeen they'll take care of it and won't charge crazy labour rates like some other shops.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4764947
thanks mate ill give it a go and what size gap do u run on your 34 and is yours turboed or na
mine is na
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4765134
You wouldn't have the part No for those plugs by any chance ?
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4765518
BCPR7ES or BKR7ES
add -11 at the end if you want the ones gapped to 1.1mm from factory.
Edit: kudos has them http://www.kudosmotorsports.com/catalog/ngkntk-m-5.html ..but most import tuners would have them in stock too.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4765551
I cant see faulty plugs throwing a code 21. Check your loom and plugs to the coilpacks. Make sure the metal connectors inside them are tight. Could it be the coil ignitor also?
On the 34 the coils igniter is built into the coil also does anyone know what coils mainly go first and also how much would the plugs cost because most of my money goes towards my house and baby girl now.
thanks for any help you guys can give me
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4765682
BCPR7ES or BKR7ES
Thanks for that, I did a quick check of NGKs site so it's interesting to note that both the Iridium (BKR6EIX-11) and the Platinum (PFR6G-11) for A 98 R34GT-t have the 1.1 gap specified.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4765919
the iridiums and platinums are a waste of money. they don't really last any longer but cost a heap more. you should be able to get the plugs at any store that sells plugs (supercheap, repco, autobarn, etc) as they aren't just used by imports. 1.1mm gap is good if the coils are nice and strong. if they were old then i would say to drop the gap, but since you say they are only 2 months old run the bigger gap in the copper plugs. unless the coils you put in were second hand then it might be a coil issue and not a plug issue (but at less than $30 for a new set of plugs it wouldn't hurt to do them anyway).
i also discovered a few weeks back that the BCPR plugs are a taller plug than the BKR plugs (by about 4mm i think it was), so they make better contact with the coils.
i ran BCPR6ES in my 33 gts-t and it was fine gapped at 0.8mm. no missfire at all and i was running the stock coils and 14psi.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4766094
my car is running fine now again and i know my car has triple platinums at the moment so are the copper ngks just as good
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4769711
yeah the copper NGKs are just as good but cheaper but may not last as long as platinums ... So what did you do/change so that it works again?
At the moment i havent done or changed anything ill put the NGKs in when i get paid on thursday
also i found when i put the car into tiptronic thats when the problem started so does anyone know
how to check the faults on the gearbox or will they come up when i check the warning light codes
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4770933
Does it come good when you give it a gut full?
Change the plugs....
Cheers..
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4770989
In your last post, you mentioned that the misfiring goes away when the car cools back down.
So I assume that the misfiring got worse when the car is warmed up...
Q. Is the car running rich? The plugs will tell you if you are.
Q. The coils you obtained; were they new or 2nds (since I know you're on a tight budget)?
Coils tend to play up when the car is warmed up completely and the car is running rich. Second-hand coils more so...
When you take out the plugs, check if you're running rich & take the coilpacks out again and see if there are any scorch marks (particularly if you got 2nds). Check the Sticky on Misfiring if they're suspect and tape them up with high quality electrical tape.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4771731
yeah im on a really tight budget with a home loan as well i got a set of second hand coils off a guy on here said they were fine
the car doesnt get worse when it warms up just stays the same if i knew someone in west sydney that had the software to turn off each cylinder i could find the problem coil and replace it with one of my ones maybe
what does taping them up do. thanks for all the help guys.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4772579
Under "Important Topics" above your thread, there's another thread called "Missfire Boost@4500-5500 RPM which tells you why taping up the coilpacks can lengthen the life of them.
I have a second-hand set which may be still suitable for an R34 NA that are 'taped & siliconed'. You are welcome to try them out to see the difference - but I'll need to check the specs of them when I get home from clinic (ie 10.30pm). They're off someone else's R34 GT-R and I keep them as spares.
https://www.sau.com.au/forums/topic/283152-need-help/#findComment-4772637
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
    • Most driving should* be done on one side of single lane divided roads. In the RHD world, you drive on the left side of the dividing line and the road is probably cambered equally on both sides. So your side of the road slopes away to the left. The same is true for the LHD world, just everything swapped to the other side and opposite slope. With a perfectly neutral, straight ahead wheel alignment designed to drive straight on a perfectly flat surface (or at least one that is level on the left-right axis, even if it has some slope in the fore-aft axis) you will not be able to drive on a cambered road without the car wanting to drift down the camber. You will need to add steering input in the opposite direction all the time. This is annoying. The solution has always been to set the camber and/or the caster to produce a continuous turning force in the opposite direction of the camber. The car will drive straight on the kind of camber for which it was set up, presumably as described in the top paragraph. But.... when the car is set up this way, as soon as you get into a lane, usually on a multi-lane surface road or highway, where the camber is not as presumed during setup, the car will usually pull to one side. In the RHD world, if you are in the fast lane on a big divided road, you are probably on the opposite camber compared to what the car was set up for (ie, sloping down to the right) and the combination of the setup and that camber will make the car want to go right pretty hard. Even a perfectly flat lane will tend to want to go right. There's no getting around it. Civil engineers who know their stuff (which is not an assumption that can always be made) will attempt to keep the variation in camber across a multi-lane road as small as possible, and if they can will attempt to make the fast lane as close to flat, or even cambered in the same direction as all the other lanes. This takes a lot of planning for drainage, control of levels, ability to deal with the elevation changes that occur at road junctions, etc etc. So it's not trivial to get it right. When they do make it work, then the annoyance is reduced, along with tyre wear, fuel consumption, etc. In theory, the civil engineers are supposed to worry about those aspects of road design also. * This used to be true, but now with very large highway systems, even just multi-lane surface roads running everywhere, it is less true now than it was, but the old assumption is the basis for describing the phenomenon, so let's just run with it for the moment.
    • I think the consensus was that's normal. Sloped road surfaces or something? I remember @silviaz went through this before. It might be one of those things you never notice until you pay attention to it.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
