R32 GTS-t Gunmetal bonnet 100$ ono
Re55 Semi x2, 2 trackdays left, 215/45/17 150$ ono
Khumo v700 bald semi x2, 225/45/17 50$ ono
R33 Diff housing and stock LSD inside, missing axel flanges. 200$ ono
https://www.sau.com.au/forums/topic/283229-r32-bonnet-and-r33-diff-used-semis/
Stripped and ready 4 you iceman
Actually, they'll fit on the rearfron of my car but not on the front... :D which means my ABS will kick in if I dont have the same overall wheel/tyre size.
So I'll have to leave it man. Sorry about screwing you around. (I really did want them. Stupid small whell arches!)
Pete.
