Hey guys i've had this problem for a while but havnt been too worried about it.
When the car is idling it might idle nice for about 10s or so then starts idling up and down, usually between 1k and 1.5k. I just got the car tuned last week and it seemed fine for a while but i've had this issue before the new rb25 went in.
I dont think its a problem w/ the tune and i read somewhere it could be the thermo sensor?
Does anyone know whats causing this? Or if someone knows and wants a quick cashy i have some $50 westfield / karrinyup shopping vouchers =D
Any help is appriciated
https://www.sau.com.au/forums/topic/283242-hunting-rough-idle/
go check out the DIY subforum, theres a tutorial on cleaning the AAC (Auxiliary Air Control Valve). It seems to be the number 1 cause of this and it was for me too.
just to drop in another idea which i found on a mates car the other day. Same deal, would hunt on idle nd run rough on idle.
What was happening was the bushes on the throttle body were worn, allowing the butterfly shaft to "wander" and would not seal properly, hence sucking air through the bushes bypassing the air flow meter
to check, i grabbed the throttle and pushed it closed. when i did this the car almost stalled and hunted worse than ever
i have never seen it before on a skyline, but just one of those weird things that happens :D
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
