For sale is my 1989 r32 gtr. As per my parts sale thread http://www.skylinesaustralia.com/forums/Fi...99#entry4751199 i'm selling up and moving on.
I bought the car in mid 2006 from a forum user in Newcastle. It was stock std when i drove it home to qld. Two weeks later it spun a big end and i then started to create my interpretation of a monster street/drag gtr.
The car has had the engine bay completely stripped back and repainted in a custom purple pearl mix. Every nut/bolt was replaced with stainless. The interior has been completely stripped, all the sound deadening material removed and the floor cleaned spotless.
The boot and rear firewall have been modified as per the pics below. I had the boot setup to take a 20gal RCI fuel cell, 3gal peterson dry sump tank, a nitrous system and a custom fuel system. The rear firewall was completely removed and a new stronger section put in. With the new firewall, i had it made rearward of the shockie towers to allow the rollcage much easier placement. With the boot modifications, the rear boot hinge components have been removed, so pins/locks will need to be installed to mount the boot. This new work has a coat of yellow (not my choice of colour :P) killrust sprayed over the top so it doesnt rust. All this work has been done in accordance with an engineer so the car can still be street registered.
All of the glass/windows were removed in anticipation of getting a roll cage fitted. I still have all the framework and glass etc to go with the car.
The car has also had the battery relocated to the boot. It's also got a lockbar installed and the complete hicas system has been removed. The std fuel lines were removed and theres currently a single -8 alloy fuel line under the car, i've got a roll of the tubing here that can go with the car also to run the other line. It's also go a new set of nismo braided brake lines front and rear. I had the wheels refurbed (lips machined and 2 repainted) at Wheel Revolution in slacks creek around 2yrs ago aswell.
The body on the car is pristine minus the odd little scratch on the front quarter panels & a bit of white paint? on the passenger front guard above the wheel arch (stinking workshops). There are a few spots on the floorpan that have some rust but can be easily cutout and replaced.
It comes complete with all the drivetrain, gearbox, all shafts etc. Full interior minus front seats and aircon. Parts missing to finish it/get it running are listed below.
The car is complete minus the following:
- Complete engine (i have a sump but has had the base cutout)
- Radiator
- Intercooler
- Front bar
- Bonnet
- Front seats
- Air conditioning/heater (dash harness has also had the aircon wires removed)
- Abs (new front lines have been made but will need to be remade in stainless)
- Fuel system
- Clutch line
- plus any other little things i've forgotten
Price i'm chasing is around $7000 as it is and the buyer takes all the spares separately, or $8000 with the interior but back in and all the glass reinstalled. I can also turn the car into a running example with engine and fuel system etc if required also, PM me if you have an option you'd like to discuss. The car is located in Ipswich, Qld.
  • 3 weeks later...
  • 8 months later...
Price drop to $5500.
Have also re-painted the shitty yellow the workshop did on the boot section with gloss black, actually looks half alright now.
  • 2 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
shane,
will you sell small bits n pieces? shoot me an email if you decide to. need a few things for mine.
  • 3 weeks later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
