ok i need to get rid of these asap. all left over from an unfinished project. all new and unused. all were for RB20DET.
Garrett GT3071R, T3 flange, .50 a/r, .64 rear housing.
Xtreme clutch and flywheel, single plate, good for 300kw.
Nismo 600cc injectors, purple, also good for some RB26.
HKS 256* exhaust cam and HKS camgears, gears for any RB engine.
$3000 the lot as prefer to sell as a whole but can seperate if there is interest in each item. I just need it all gone as its doing nothing here. pics on request but ill get some up asap and im sure you know what they look like. oh shipping at buyers cost.
that is all....
Edited by RB ONEVIA
https://www.sau.com.au/forums/topic/283258-need-to-get-rid-of-these-parts/
turbo and cam gears sold pending payment. the rest of it needs to go. give me offers as long as they stupid.
:cool: well ok
pm sent
Edited by HI2U
  • 4 weeks later...
  • 1 year later...
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
