And so the story goes like this.
This afternoon, I was at Kingsway, Glen Waverly, wanting to get some pork. While i was looking for a parking lot, my girlfriend suddenly felt pukish. So i just put on my hazard lights and ran into the shop to get a bag for her. When i came out, the girlfriend showed me the infringement notice.
It says STOPPED - DOUBLE PARK
And i have to pay $70.
Do i contest it? Or should i just pay the fine. The money doesn't matter so much, but i was gone for like, 20 seconds.
Yeah, you did something wrong so you technically would need to pay. But I personally would write a letter explaining the situation, and see if they show and leniency. Most likely you will need to pay.
Why did your girlfriend not talk to the parking officer? Was she even visible or was she like in the bushes chucking?
if you couldnt talk to the parking dude at the time, i wouldnt bother about it, fines been written and done, $70 is like a full tank, but not really worth the worry and bullshit you have to go through to cancel it.
or you could exaggerate the situation, saying you miss's was curled up on the front seat with bad pains, so you did what any boyfriend would do, and that asshole inspector didn't even care to see if she was alright while you were gone for all of 1min max.
give it a crack either way, the worst that can happen is that you pay your $70 :P
Common sense would have gone a long way here, if any one in my car says they feel like spewing they get kicked the f**k out, do you know how hard it is to get the smell of spew out of your car, not to mention how violated the car will feel, you have betrayed its trust, it will for ever hate you.
i always thought double parking was something similar to those tools you see just stopping in a lane, jumping out to buy ciggs and jumping back in. they are double tools when you want to reverse out and they're blocking ya. just pay the fine and be weary next time. did she ever throw up in the end? :P
Yeah she did, in that plastic bag i for her.
Well, all i did was stop behind 2 full lots, but i now know you can't do it here.
Alright, i'm too lazy to go contest it anyway, i heard its a super long process. Will just pay the fine i reckon.
You're lucky it wasn't the "Loading Zone" around the corner in Colemen Pde near the station. $117 fine for a 10 second stop - I always thought it was a "drop off" area since there's nowhere else to stop on that side of the road - unless you're a taxi. (I'm an unofficial taxi but that doesn't count.)
JH
And today when i tried to pay the fine, it says that the infringement number was not found.
How long do they take to update the system anyway? Its been 4 days, or 2 working days. Do they really need to take that long? I thought it was all seamless.
I think its pretty much instant, at the most it would be in there when they get back to the office.
Yeah I got some $70 odd fine for parking my car over night around the corner from the pub in a two hour zone. The only sign was about ten metres away with an arrow pointing along the wall. I did the right thing and didn't drive and I get fined for it :D Just payed up though. could not be bothered with the whole lengthy proses of contesting
If you follow the instructions at the back of the ticket, it should be right. Make sure you went to the correct site to pay for your fine. If not, just call them up and pay with your credit card through the phone.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
