hey all,
I've just read the topic at top about the oils to use on your vehicle, but I'm still confused on what to use.
First of all my vehicle idles above 1000rev's in the morning wen its cold. Seems like my mechanic over filled my engine. Since I've got the car it seems like the car didn't burn any of the oil. It's still above the H line.
It's a road car but I'm thinking of making it a track car as well.
Can anyone think or tell me what's the best oil to use.
I tend to get confused on this so much, fact is so much information around that you don't know which one to take.
Thank You
https://www.sau.com.au/forums/topic/283262-oil-for-my-gtr-r32/
With RBs its ok for the oil level to be slightly above H as most of us track go'ers overfill anyway. Depends on your budget and how much you want to spend every 5k oil change? Ideally a full synthetic 5W-40 or 10W-40 is what you want.
Yeah money doesn't matter to me.
My vehicle done about 96,000km's and i just want a oil that does it job and not wear out my engine.
I'm doing about 5k-7k oil change. What brand is good because I see a lot of brands around.
Thank you.
hey all,
Thank You
That's normal for you car to rev over 1000rpm in the morning, cuz the car is cold. Once the car is warmed up the revs will drop to 1000rpm.
Depending on the condition on your engine...
From my understanding, R32's were made back in the day where Mineral based oils were available and that's what Nissan had use to engineer the car.
A lot of ppl go full synthetic, but a top quality Semi Synthetic would be just as good for the older RB engines.
It's normal for turbo cars to burn a bit of oil, just make sure you do your regular top ups.
Motul Chrono 300V is probably the very best you can get, its a 10w-40 Full Synthetic (but a unique full synth being that it's double ester).. expensive, works out to be about $140 for 6l (only comes in 4l and 2l bottles).
I use Motul 8100 X-Cess, it's a 5w-40 full synth and is about $75 for 5 litres, there is another Motul 8100 that is 10w-40 which is same price roughly.
Motul 4100 Turbolight alot of people here use, its a top quality 10-40w semi synth and its about $50 for 5 litres. Perfect for a street only car imo.
As for cheap alternatives for good full synths, have a look at performancelub.com the Mobil 1 and German Castrol in particular (the Redline on there is a very good full synth, and the Royal Purple XPR is a very good synth as well, the Amsoil another full synth that has a pretty good rep in the states)
G'morning all
Thank you for all the advise guys, i might give the Motul Chrono 300V 10w-40 full Synthetic a go first. See if my car will respond better, if not I'll give the Amsoil a go as well.
BTW do you know where I can get these products? I'm located in Perth.
Thank you very much for the help!
SLinky-{A}
yep, I vote for the motul chrono 300V too. it's a great oil. I have done UOA (used oil analysis) on my old GTR and the results were very good, I've also got some info from motul here on their analysis and as expected it's a great product. expensive but worth it in my opinion.
If money really doesn't matter Redline oils appear to have better HTHS than the Motul 300V, but they seem to be a fair bit more expensive, so i cant see that its really worth it. Much more important than worrying about which oil is worrying about oil starvation and temperature. Before track days i fill the oil up to to bottom of the bendy bit on the dipstick, which is a fair bit above the H mark. I also have an oil cooler and keep a close eye on the temperature, and stop if it gets to 110 degrees.
Hey guys,
Thx again for the information, I'll got my service next week because my car still got warranty.
I'll give the mechanic a call and tell them to order in Motul Chrono 300V 10w-40 full Synthetic.
I'll give updating on how the oil go's.
Thx
SLinky-{A}
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
