Probably cause your ecu is trying to protect the motor! Stock turbo can't go past 13, at 14 it will blow the turbo. U got a pretty cheap controller? hence the spikes!
Probably run a few more mod- cooler and turbo back exhaust if u wanna run more than 10, then your ecu needs to be changed or remapped.
U will find the highest boost on redline gear 3!
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4766421
ok, the turbo won't blow the moment you hit 14psi. i was running my stock turbo on my 33 at 14/15psi for a year and never had an issue. i know people who have run up to 16psi and not had an issue.
as for the ecu stopping it from going any higher, that isn't right either. the ecu has protections in it, but it won't magically stop it going any higher. you can go higher but it will start throwing tantrums. without knowing your setup i couldn't say why it isn't boosting any higher than 13psi. if you still have a stock exhaust then that would explain it, or if you still have a stock cooler, that could also be a contributing factor. or it could be a problem with the controller.
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4767202
Yeah as mentioned above your ecu wont control boost. your turbo won't blow at exactly 14, could blow at 12 or could last years at 15 it's always a gamble.
Gizzmo controller is not a cheap unit and is a quality bit of gear so i wouldn't worry about that.
the advice to run bigger exhaust and cooler is spot on it never hurts to have more cooling and flow.
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4769019
its got a frount mount and a cat back exzaust allready on it
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4770440
Your probably running out of a lot of things, fuel, turbo, spark even.
Try getting your fuel pressure checked, regapping your plugs to 0.8, check your wastegate setting, turbo size?, dump system?
My thought anyway.
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4772453
My thought anyway.
just got a brand new walbro fuel pump dont think it would be that
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4772686
Did you run a separate earth? fi you just replaced your pump and the car is playing up, I'd start there.
PS did it do this before you replaced the pump?
https://www.sau.com.au/forums/topic/283263-boost/#findComment-4776343
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
