Hey
Anyone out there help me with this, I had a Carrozzeria Head unit with Carrozzeria 6 Stacker Cd and speaker amp, it was factory in my r32 gtr.
It was working perfect in my car and I took it out as I upgraded to a mp3 player. Now when a friend installed the Carrozzeria head unit with stacker in his car its works perfect as well, sounds fine etc and the head unit lights all light up, every thing works find apart from the display on the screen on the headunit, it dosnt show anything. But it was working fine in my car and never been dropped or got water on it etc.
Can anyone please let me know how to fix this or what to do plz
Thanks
M3M3NTO
https://www.sau.com.au/forums/topic/28327-help-with-head-unit/
I just got told this, can anyone confirm this please???
"some jap head units have an encoder which stops the screen comming up in case of theft
u need the owners manual to have the button sequence to get it back"
Anyone help?
I have a carrozerria DEH990 and Ive removed it from my car and operated it directly from a 12volt battery. The display came up correctly and worked fine. This sounds a bit odd (what your friend mentioned). Does the face flip down to allow you to put a CD in? If so check the contacts for the silver/brass part where the wires connect internally.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
