Factory settings are below: (note this is for stock suspension)
Front
Camber -0degrees45' +/- 45'
Caster 6degrees 35' +/-45'
Toe (mm) 0 to In 2
Rear
Camber -0degrees55' +/- 30'
Toe (mm) 0 to Out 5.2
Note that Camber and Caster are in Degrees and minutes
    • Holy hell! That is absolutely stunning! Great work!!!
