Anyone know anything about banking laws specifically relating to when a payment(direct debit) falls due on a weekend or non-banking business day, as to when the company can make the debit request?
I always assumed that it was the next banking business day.
https://www.sau.com.au/forums/topic/283350-banking-laws/
The company is legally entitled to make the debit on the agreed date between both parties, whether or not this falls on a business day is irrelevant. (But realistically speaking, the debit is usually made on the next business day.)
https://www.sau.com.au/forums/topic/283350-banking-laws/#findComment-4767717
It all depends on the specifcs of the direct debit authority that you signed. A lot of PD-C type agreements have the ability to vary dates and other conditions - apart from the amount.
A good example is if the debit is scheduled for the last business day of the month, this will be different dates most of the time.
Just call your Bank, they will tell you, or ring the organisation in question. You wont get a clear answer here - it's a car forum!!!
https://www.sau.com.au/forums/topic/283350-banking-laws/#findComment-4767833
A car forum with lawyers and accountants :P :P
I guess I'll need to dig up the agreement. I always thought that there was a law that a payment couldn't occur before the due date, and had to fall on the next bank day, kind of the like the one that pay must be received by the due date, and so fall on the previous bank day.
https://www.sau.com.au/forums/topic/283350-banking-laws/#findComment-4767992
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
