OK, the time has come!
I am organising a paintball outing for club members.. this will be a casual punter day with possibly a beer down at the Serpi Tavern afterwards.
Date: Sunday, 25th October 2009
Time: 12:00pm (best to arrive about 11:30am)
Venue: Action Paintball Games WA, Punrak Rd Serpentine
Will require a $50 deposit the week before which covers a basic marker and goggles hire and you get a free 100 balls for depositing early. After that, pricing is as follows:
There are also 3 levels of upgraded markers available:
$20 upgrade - BT4 Combat, mechanical marker with an agitating hopper. Better barrel and slightly higher rate of fire compared to the base gun.
$30 upgrade - SmartParts Ion, entry level electro-pneumatic marker. Huge rate of fire compared to the mechanical markers.*
$40 upgrade - SmartParts Shocker, tournament level electro-pneumatic marker. Huge rate of fire and better barrel than the Ion.*
*I highly suggest that if you decide to go for one of the electro markers, that you also get a large paint package because you will chew through the paint rather quickly.
Camo overalls are provided and it's best not to layer up big time underneath because you'll get rather hot in there. Some sturdy shoes that you don't mind getting dirty is also the go :thumbsup:
Attendees:
- bubba
- R Dirty 3
- Mr Keets
- Marco
- Ossie 21
- Pattygtst
Edited by GTS-t VSPEC
https://www.sau.com.au/forums/topic/283354-sauwa-paintball-day/
  • Replies 70
$100-150 is a good day out paintballing.
If you're getting a mechanical marker then a SCOUT or TROOPER package is good.
If you're getting an electro then a COMMANDO or TERMINATOR package is the go.
The 2000 round package seems to be a bit much for most people even with electros.
The electros are the most fun and I'll let you all have a fingerbang of my favourite toy too :P
Edited by bubba
Once we have more of a list of people (and closer to the date) I will start taking desposits. The deposit covers your initial equipment hire, 200 balls and a free 100 balls, any extras (paint packages/upgrade markers) will need to be sorted out on the day once you get there.
P.S. I'll need a mod to add people to the list!
Edited by bubba
Hmm....should I really spend my birthday being shot in the nuts (probably) all afternoon??
Survey says....yes
Absolutely!
Mary spent her birthday standing on the side of the field getting shot at.. at least you'll be able to shoot back!
  • 4 weeks later...
Guest
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
    • That could be drilled, ground and welded. Would stop it progressing and leaking. But that block shouldn't be pushed very hard, as what you see there is a massive warning sign. But that fix also isn't going to happen properly with the engine in the car, and assembled. So you're looking at anew block if you're doing all that work anyway.
    • It's not as simple as it is being made out to be. It s not hard, but there are things that have to be done. Am busy right now, but will try to essay later.
    • Pinout is different to my knowledge, but you should confirm to be sure. Also you will need to adjust the VQ table in Nistune to suit. I would still recommend sticking with recirculating BOVs, I'm not sure if the R35 card MAF will fully resolve stalling caused by reversion/throttle lift.
    • What issues are those? Previous owner said it wants to stall sometimes. We did test drive and it was nice and smooth so it will be sporadic or idk. And if i just change MAF(the sensor to R35 version) it should be better? And as i asked...is it like "plug n play" with oem MAF from R34?  This is a MAF from R35 right?
