OK, the time has come!
I am organising a paintball outing for club members.. this will be a casual punter day with possibly a beer down at the Serpi Tavern afterwards.
Date: Sunday, 25th October 2009
Time: 12:00pm (best to arrive about 11:30am)
Venue: Action Paintball Games WA, Punrak Rd Serpentine
Will require a $50 deposit the week before which covers a basic marker and goggles hire and you get a free 100 balls for depositing early. After that, pricing is as follows:
There are also 3 levels of upgraded markers available:
$20 upgrade - BT4 Combat, mechanical marker with an agitating hopper. Better barrel and slightly higher rate of fire compared to the base gun.
$30 upgrade - SmartParts Ion, entry level electro-pneumatic marker. Huge rate of fire compared to the mechanical markers.*
$40 upgrade - SmartParts Shocker, tournament level electro-pneumatic marker. Huge rate of fire and better barrel than the Ion.*
*I highly suggest that if you decide to go for one of the electro markers, that you also get a large paint package because you will chew through the paint rather quickly.
Camo overalls are provided and it's best not to layer up big time underneath because you'll get rather hot in there. Some sturdy shoes that you don't mind getting dirty is also the go :thumbsup:
Attendees:
- bubba
- R Dirty 3
- Mr Keets
- Marco
- Ossie 21
- Pattygtst
Edited by GTS-t VSPEC
https://www.sau.com.au/forums/topic/283354-sauwa-paintball-day/
  • Replies 70
$100-150 is a good day out paintballing.
If you're getting a mechanical marker then a SCOUT or TROOPER package is good.
If you're getting an electro then a COMMANDO or TERMINATOR package is the go.
The 2000 round package seems to be a bit much for most people even with electros.
The electros are the most fun and I'll let you all have a fingerbang of my favourite toy too :P
Edited by bubba
Once we have more of a list of people (and closer to the date) I will start taking desposits. The deposit covers your initial equipment hire, 200 balls and a free 100 balls, any extras (paint packages/upgrade markers) will need to be sorted out on the day once you get there.
P.S. I'll need a mod to add people to the list!
Edited by bubba
Hmm....should I really spend my birthday being shot in the nuts (probably) all afternoon??
Survey says....yes
Absolutely!
Mary spent her birthday standing on the side of the field getting shot at.. at least you'll be able to shoot back!
  • 4 weeks later...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
