I wanna Know what head gasket is the best to use on my rb20 running 20psi 240 - 260rwkw
Ive blown two gaskets on my car since having it into cylinder 2
once when the car was fairly stock
and now ive built my car ive blown gasket yet again what can i get to stop this happening?
i think we used a genuine nissan one (supposedly pretty good for power im making But yet i prove everyone wrong)
My luck just sucks......... What are the main causes of a head gasket Blowing???
Any help......... what can i use top of the range?
https://www.sau.com.au/forums/topic/283445-blown-head-gasket/
Who put the motor together? I'd be squarely asking them this question (it should not have blown)
If its all machined up properly, even and so on, you should not be blowing gaskets.
Stock one should be fine, its fine for everyone else :huh:
If its also blown out @ the same point - then that is even more indicative that the surfaces are uneven.
mmm ok
i know there isnt any cracks in head or block cause we had it all checked at the last build
i need a new cylynder head now anyway cause the head has some detonation on it too
so it needs to be all machined again to fit
is there any other causes??
Well if you've had detonation... i do indeed believe this can kill a head gasket.
But if the valves have noticeable detonation... then what do the pistons look like? If you've damages values/head then there must be some evidence on the pistsons.
IMO it sounds like the setup needs to be totally looked at in more detail and carefully, this is the reason the gasket has died. Not because its a Nissan one.
ok well that may explain it then
what happened was my fuel reg went on me about 3 - 4 months after the build
i i must admit i did drive it pretty hard for a bit once the car was all run in ect ect
we put it up on the dyno and found it to be leaning out at the time
we fixed it and hoped for the best
i suppose this is the result and yes even the piston in only cylinder two is damaged
im rebuilding again as we speak :huh:
well it is bad luck if the fuel reg sh..t itself out of the blue
how reliable should an engine like this be?
answer is not very i suppose.
just wanna prevent it happening again i should be able to track this car if everthing is right
what do you think of a different head gasket? metal or copper?
what running gear do cars need to run big boost? say 40 psi
im only running 20psi nothing more but i am still having problems
Very reliable IMO. Well, obviously parts will fail here and there, 15yr old car it's to be expected.
A fuel reg dying shouldn't kill a motor mate. I've had two die, they just over fuel to the shizen... they should not go the other way and lean out i don't think?
ok i didnt know that.
i think at the time the car just didnt feel right and he threw it on the dyno and thats what he told me
the fuel reg went and it leaned out a little
but he wasnt really worried about it cause the car seemed ok
but its just now since the gasket went and leaked water into the cylinder
by the time ive seen water temp go up damage is already done
What sort of management are you running, if you have a power fc with the hand controller mounted in the cabin you would have been able to see the knock go up and then be able to do something about it, at the least you should have an afr gauge which would have shown it leaning out and you could have done something about it before blowing the head gasket, although you say its bad luck remember the old saying "Luck favours the prepared".
Also i would recommend machining the head and block to make 100% sure you have a good mating surface.
Edited by W0rp3D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
