Hi All,
I am doing some reading on s/s braided brake lines for the V35 and so far, have come across these brands:
1. Earl's (popular in Japan) ....sub $200 USD delivered
2. Stoptec ...low $200 USD delivered
3. Goodridge...low $200 USD delivered
All of them are TUV, DOT, etc approved in the US.
I just wanted to know if any of you have braided lines for your car, and if so, which brand? I've also heard that it is illegal to have these on your car...Anyone shed light on this?
RS73 told me that he enquired about street-legal ones, but they wanted $500 for the set of 6.....(yes, V35s need 6 lines and they are all the same couplings for Brembos and Non-Brembos)
The cheapest should be Earl's (since they have an office in Syd) and I have already enquired about pricing.
Maybe it's time to setup a GB????
https://www.sau.com.au/forums/topic/283446-stainless-steel-braided-brake-lines/
Well, Earl's just got back to me....they don't do street legal brake lines....so maybe the myth is true....s/s braided lines r illegal in Aust...
ive had MALTECH lines on my 180sx, which are ADR approved and made in OZ
excellent product
i had nismo lines on my s15 but they werent adr approved.
if insurance knows what they are looking for your insurance is void if you have non adr approved braided lines.
I looked up an old email from Maltech, $435 to be precise. last year May.
so you could get USD$200+ shipping which won't be ADR and will void your insurance if they find out about it,
or around $400 but you keep within conditions in your insurer's policy, ie. all parts are street legal.
I've got Maltech lines on the Z33, which are ADR approved. I don't know how well (or how badly) brake lines can work and I also did a Brembo caliper upgrade at the same time so I can't even accurately comment on feel. I have tracked the car since and not died. They're a Victorian company to boot.
V-Sport sells Goodridge lines, which are apparently also ADR approved.
I had Maltech one on my R33 and it didn't have a clear cover put over the top.
It does however have a round 1cm of rubber sleeve at the end of the hose fitting, with ADR approval number imprinted on it.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
