ive got a r33 s2 and want to put my z32 afm and to have the car run , I know you have to go to settings then air flow but when I go there it says r33 normal and when I press next it goes to a list of voltages what am i supoosed to do the set it up run a z32 i havnt been able find my answer searching or on pauls faq
https://www.sau.com.au/forums/topic/283455-how-to-set-pfc-to-run-z32-afm/
its in the FAQ - select VG30 AFM From the menu - the VG30 is the engine which uses the Z32 AFM
this will load the base ramp values for the Z32 - it still needs a full tune when you change AFM
if your car is relatively stock it will be fine if u drive it steady. I put my PFC in for a bit one day for a play and just ran around off boost at lower revs and it displayed next to no knock. The base map is pretty fuely i think but as long as u drive it to your tuner (if hes not a great distance away) really lightly it should be fine. If you have any doubts just run the stock ecu till u get there or nearby and change it then
It wont be driveable.
Yes it will!
I put a Z32 AFM in my R33 GTSt about four weeks ago, changed the PFC over to VG30 AFM, and have been driving it daily on the base PFC maps. Got a wideband Oxygen sensor and it holds around 12 when accelerating hardish, and around 14 when cruising...cruise is a bit rich for my liking...knock is always low though...
Other related mods are FMIC, 3" turbo back exhaust, pod filter, 10psi boost etc...
Going to put bigger injectors in soon, and then off for a tune... :D
Peter
Willing to put his motor on it?
It has been tuned for the current AFM, so it wont be running hell rich like a stock map which basically couldnt kill a motor if you tried...
Most likely the tune will be close to perfect, not rich and so on. Adding in a larger AFM could spell disaster.
I think its a silly risk when it is a 15min job to change at best, i would drive to the tuner, change the AFM when you get there, rest assured you will not mince anything.
Fair enough....my oversight...I agree....
Quick reply I must say...your like a hawk! :D
Pete
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
