ive got my gtr for sale which is extensively modified. mods follow as below
step 2 HKS pistons oversized to 87mm
Eagle rods
blueprinted and balanced crank.. 10k safe redline
step2 HKS cams 272deg 10.4lift both inlet and exhaust
machined valleys to fit cams, exhaust and inlet ported and polished and enlarged.
HKS valve springs and retainers
HKS cam gears and belt
modified standard oil pump for more flow and pressure
oil galleries modified in the head
trust sump extension.. now holds 7.5lts of 300V
all gaskets including headgasket lifted from the nismo race car.. fkn expensive!!!
block bored to 87mm cap up from 2568 to 2650 roughly
stock exhaust manifolds ported and enlarged to suit a pair of GT2871r -10s
really f**king quick...
custom Jim berry clutch full monty... cost too much but best clutch ever.. easy to use and no slip at all.. built to withstand 800kw according to the man himself
aftermarket dump pipes.. unsure of brand.. possibly xforce.. full 4" exhaust cat back.. also comes with stock exhaust for epa purposes
exterior clean and stock.. originals and black metallic paint job
has slotted rotors and new bendix ultimate pads
Apexi N1 racing suspension
Greddy strut brace
interior clean except for a bubble on the passenger side dash.. seats and carpet in excellent condition. no wear marks at all because i dont even drive it.
roof lining perfect
has jvc dvd player, Gizzmo EBC, autometer ultra lite series gauges.. boost, oil pressure and a/f meter
standard GTR steering wheel unmarked
car is running 300V chrono in the motor and gear ff Comp type 2 in the 2 diffs and gearbox..
new fluid in transfer case
Engine has approximately 99xkm on it.. i ran it in and that was it...
No rwc but with 12month rego august 13th 2010 :huh:
looking for 25k firm.. spent alot more then that but im in the shit and it needs to go asap.. ive got 1 week to get rid of it and find somewhere to live :P
Thanks guys
p.s will get photos up tonight including photos of the reciepts for the engine
https://www.sau.com.au/forums/topic/283457-r32-gtr-1993-for-sale/
Just as i was speaking to you at your shop yesterday afternoon that you mentioned you wanna sell your car :P. Can't wait to see the pictures
I can assure that you'll be spewing when you see the new owner drive your car away :huh:
  • 1 month later...
ok update... car still for sale
it has been broken into so i will be replacing the ignition and wheel locking system
should be back together in a couple of weeks
sorry for the delay guys
  • 4 weeks later...
Ok.. this thing needs to be gone..
20k.. i know im losing heaps but it needs to really go
20k as is
if u need to know what it needs to get a rwc call me up and ill let u know..
  • 1 month later...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
