  • Replies 214
Posted Images
Well i made a new set of drivers side seat rails again today and i am still not happy with them.
The first design was custom adj sides mounted to the factory bolt holes, due to the seat having a large lip on the lower front edge i could not get it to side far enough back for me (too tall).
The next one was straight to the floor pan of the car this gave me good height and allowed the seat to slide back heaps but cause the slide sits next to the seat i could not get the seat dead centre with the steering column (10 mm to the right GRRRRR).
So it is back to the drawing board, i am thinking about some square rhs with three nutsert threads in it and three sets of holes in the seat mts to allow some movement back and forth (No adj slides). My only problem is the nutsert threads are only M6, i am a bit worried about there strength.
If anyone has some good pics of their mounts or some ideas that would be very helpful.
Cheers.
Andrew,
I drilled into the lower control arms up front on the cross memebr I think? so as you move the hole to put some bolt it...it pushes the bottom half out.
I had just over -4 camber up front
was wicked!
hurry up Ryan!!
we gotta hit the track together!
I did some thing similar. I only moved the arm up looking for better roll C. I have seen some redrilled out where the cross is for camber as well.
As for camber in mine, I used a big mofo rose joint rod end and nut.
Edited by Noddy
  • 3 weeks later...
Well it has been a while again, but the progress is picking up slowly i have primed and painted the inside in GMH acrylic black, it is the closest thing i could find to matt black. It looks ok and should not rust or reflect any light at me.
I just have to wire it up over the next three days and try and finish inside the car.
Yes I have something running :)
Yes I want to come down but it is the same weekend as the mid year Noosa Hillclimb. :spank:
You should come for a blat up the hill in the november event dunc. its on Nov 13/14, I think its the weekend before the national supersprint, Nov 20/21?
Sorry for the side track Ryan. I like your cage by the way.
Absolutely perfect mate. I will be up for the nationals if I have to bring a push bike. I just need to impose on someone near morgan park to store the car for a week :) send me details as soon as the other weekend is open, I'll be in and I bet Neil will be too.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
