My R33 Gtst Project
BOZ22N
 Share
  • Replies 214
Posted Images
All this talk about Morgan Park is depressing me.
Ryan,,,questions on what fuel system are you running if I may be so rude.
Would I be correct in assuming you are using the factory pump as a lift pump and an 040 as the supply pump. Also what size is that surge tank?.
Cheers
Neil.
Come on Neil and Ryan, even I'm going to Morgan park!
Annual leave approved today... :banana:
Well if one of you guys would be so kind as to ring my boss and tell him he can't have hols then I will be there.
Good luck I couldn't even get him to start them on the tuesday.
shit happens
Neil.
quit like I did..hahahahha
Do what he said...
Oh and it looks like I go to Morgan park one weekend ( I should tell my missus about this hey?) then I go to Thailand the Sunday after, then I go to the ACT the day after I get back from Thailand... Awesome two weeks!!!
  • 1 month later...
Well not much doing on the car but went and purchased some race gear i got some boots and a suit all from Monaco Performance Newcastle, i decided on the GTRacegear range due to its great price and exceptional quality. Below are the links to the pages feel free to PM me if you want any info on them. Bring on the 2011 season so pumped.
Suits
shoes
Monaco Performance
Cheers,
Ryan
lol I thought Ryan was the blonde.
too late for you mate, and looks like they are OK anyway....but be aware the CAMS rules for boots are changing next year (actually they changed 2 years ago but there was an amnesty). You now need to the FIA standard (as yours seem to), not just the SFA or whatever the other standard is called
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
