  BOZ22N said:
Well just a quick up date the car has been delivered to Brads to get the cage sorted so hopefully i will have it back in a few weeks to finish painting the inside then it will be full steam ahead re assembling.
I will try and up date some picks along the way.
Great build up looking very promising and can't wait to see the end results! GO THE GTS-T! :thumbsup:
  • Replies 214
Posted Images
I picked up my clutch today form its little overhaul. I am still retaining the 5 puk button clutch arrangement but went with a different clutch plate for increased strength and a different button material.
I got carbonic buttons fitted instead of the ceramic ones and a larger and stronger centre out of a 4.2TD patrol. There was nothing wrong with the old one but its limit is around the 300rwkw mark so instead of killing it i went for a new stronger one to last the distance.
My new one is the bottom plate.
Also to get some more clamping force we changed the pivot point in the pressure plate and also added another tab on each point to give it some more strength. This is still the same pressure plate that i have been using the last 3 years, just tweaked up and skimmed.
Hope you like and i will add more pics as more stuff happens.
this is the cage kit we have for Ryans car.
The hoop has been trial fitted and is a really good fir to the b pillars and roof line of the car.
Next few days ill get the rear section and front legs done with more photos to come
It is a bonds kit but not the hoop, the hoop is bent up from a jig I have for the R32/33
I was not entirely happy with the hoop for Ryans car so this is my own hoop and ill be using the one supplied in his kit for my little S13 project which im happy for it to sit a few mm off the sides.
The bonds hoop is very good and typically id use it without an issue but its not tight enough for what I wanted for this cage. There was about 8mm each side, this hoop has 0mm each side, it actually requires a rubber mallet to get into place.
Dont get me wrong the supplied bonds hoop is great and ill post up the trial fitment of it.
the legs they are very tight and supplied by bonds, they require some tweaking in the bender but fit very neatly now.
Edited by Risking
Ive been slack in putting photos up with Ryan's cage but it has progressed and coming together.
Basicly everything is knotched and has been trial fitted then touched up to fit nicely. So now im onto the final assembly of the cage.
Sorry Ryan but once there is holes in the floor and plates welded down you know there is no turning back
The hoop is a sensational fit inside the car. It literally needed a tap with the rubber mallet to get level.
The front legs went in as did the windscreen bar, then it was lowered through the floor to make up the roof diagonal and weld up the tops of all the current bars. The front legs are a nice fit. There is just enough room between them and the pillars to fit thin padding if nessisary.
The whole thing was then raised back into position and sat on the plates.
You can see how close the roof diagonal is to the actual roof by looking at the shadow. Ryan is tall so we've had to adjust the bends and compromise a few areas to accomodate his height.
The rear legs were cut and knotched then the mounting plates welded to the body. Typically id rather go to the towers but its rather difficult on the R33 to get the harness bar mounted within the rules so we went to the arches instead.
In this photo you can see the mock up string line for the first diagonal as well.
First rear diagonal cut and in place.
Here is an artists impression of what still has to go into the cage
Thanks for the kind words guys.
Chris, it went well mate Brad has been putting heaps of thought into this one to accommodate for my height. I sat in the passenger seat of Jays new car and my head was hitting every where (but that seat could be lowered another 80mm or so). Then when I sat in mine you could appreciate the little extra bits that will make my cage usable for me :P . All things going well it will be back in my shed next Sunday night if not it will be the following weekend. Then I will be flat out through Nov and the start of Dec, and I might try to get it out for a sly track day before Santa comes. It was good to see ya all yesterday, we will all have to sign up for heaps of track time in 2010 hell yer :banana:
well here you go Ryan.....
In these photos its basicly finished besides the final weld clean up and welding the cage onto the bases. (its left loose on the bases to tidy up the welds with a small sander just to make sure they are neat as can be)
ALOT of extra work has gone into this cage to accomodate the height needed.
If you look closely at the photos you will see just how close the roof area bars are to the original body work. The front leg supports cant get any tighter nor could the roof diagonal or main hoop. There is just enough clearance for padding on the front legs and windscreen bar.
The harness bar in the rear has nice little lugs that I machined up and welded in to suit the eyelets.
Holy crap that looks sweet ;) .
You have out done your self Brad, the work man ship of the cage is second to none. The wife and i have made a few trips down to look at the progress and believe me the 7 hr round trip is worth it. I can not wait to get back to work on it and get it finished.
A big thanks goes out to you Brad for all the hard work that has gone into this cage to squeeze a 6 3" person into a japanese car with plenty of room around my helmet, cheers mate. :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
