  • Replies 214
Posted Images
  • 1 month later...
Hell yer it does, I need to spend more time in the shed and less time working and stuff. :)
I trial fitted the seat this arvo, I made the rails for the Sparco on the weekend and I just used the Bride rails for the OMP but cause the OMP is a little bit larger in the ass than the Bride I will have to make rails for it also :) .
You can see in the pic I have made the brackets for the steering column and fitted the RPM wheel and the D2 quick release do dar.
While I was spending I purchased a 2" Sabelt 4 point harness for the passenger side, I made up the plates on the weekend for the harness mounts and they are ready to be tacked on under the car.
I also finished welding in the front legs of the cage and filled the sills with the expander foam, that stuff is crazy :blush: .
I also mounted the surge tank and fuel pump assembly in the boot too.
So all in all I am getting there very slowly but this time of year is crazy busy, I was hoping to have the car all painted on the inside by Christmas but that will not be happening now, it will have to wait till next year.
That is a wild looking cage. Does it go through to the front towers as well? couldn't see a pic showing that area.
Nar Noddy, i was thinking about it but i would have been such a pain at this stage cause i would have had to run no booster and change the master cyls, pedals etc. But i did get the dash bar made out of 44 mm tube so i can hang a pedal box off it later and run fwd supports at a later stage.
I have been meaning to Pm you about you car for a while now but have never got around to it, so expect a little PM soon bud.
Thanks for the kind words.
Ryan
Well after a frustrating day on the car i have made new mounts for the drivers seat twice as the first ones retained the std front mount, but the seat fouled on it when i slid the seat back for my height so i had to chop out the mounts and weld up some new ones directly to the floor. I just have to pick up some RPM side mount rails on monday to fit to the sides and brackets i have made then fingers crossed it will all be complete.
I fitted the OMP passenger foot rest and primed up the passenger seat mounts, and fitted the harness support plate so fingers crossed this side is complete.
So i cut and fitted the dash today also, so excited as it was starting to look like a car again until i found that the dash bar runs directly where the factory cluster is ment to be :P . So i need to sort out what i am going to do about gauges? Do i buy a shit load of cheapies? or do i spend up and buy a Stack dash or similar? Does anyone have any ideas on alternative dash?
Also i was inspecting the sump i had moddified and found that they had not cleaned up where they have cut the sump with the grinder so they is a shit load of metal in my sump that needs to be ground off and cleaned up. So the baffel plate needs to be cut out so i can clean up the grinder cuts woohoo, i am so so so pissed off. :geek:
So all in all i made one step forward and two steps back, happy new year. I will post up some pics and more info on Monday as i hope to kick a few goals then. For now it is beer O'Clock.
Same, O well, hopefully not too many more hurdles.
Got a reply about the IQ3 dash today, they don't have a interface with the Apexi ECU but hopefully we can work around that some how for not too much coin.
if I was doing this all again I would cough up for digital dash for sure.
individual gauges are expensive once you get them all and a pain to wire in.
digital dash does all that (still need senders of course), plus you can set it up to suit you, plus its simple, plus you get datalogging when you are ready for it
They are just so so expensive Duncan, and an expense i was not ready for. :banana:
If you can live without your AiM dash and Power Fc for a few weeks they will send them off to Italy to configure the data logger
What you talking about Roy?
I inquired about the AiM My Chron 4 and the MXL today hopefully should hear something back tomorrow.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
