  • Replies 214
Posted Images
Well i made a new set of drivers side seat rails again today and i am still not happy with them.
The first design was custom adj sides mounted to the factory bolt holes, due to the seat having a large lip on the lower front edge i could not get it to side far enough back for me (too tall).
The next one was straight to the floor pan of the car this gave me good height and allowed the seat to slide back heaps but cause the slide sits next to the seat i could not get the seat dead centre with the steering column (10 mm to the right GRRRRR).
So it is back to the drawing board, i am thinking about some square rhs with three nutsert threads in it and three sets of holes in the seat mts to allow some movement back and forth (No adj slides). My only problem is the nutsert threads are only M6, i am a bit worried about there strength.
If anyone has some good pics of their mounts or some ideas that would be very helpful.
Cheers.
Andrew,
I drilled into the lower control arms up front on the cross memebr I think? so as you move the hole to put some bolt it...it pushes the bottom half out.
I had just over -4 camber up front
was wicked!
hurry up Ryan!!
we gotta hit the track together!
I did some thing similar. I only moved the arm up looking for better roll C. I have seen some redrilled out where the cross is for camber as well.
As for camber in mine, I used a big mofo rose joint rod end and nut.
Edited by Noddy
  • 3 weeks later...
Well it has been a while again, but the progress is picking up slowly i have primed and painted the inside in GMH acrylic black, it is the closest thing i could find to matt black. It looks ok and should not rust or reflect any light at me.
I just have to wire it up over the next three days and try and finish inside the car.
Yes I have something running :)
Yes I want to come down but it is the same weekend as the mid year Noosa Hillclimb. :spank:
You should come for a blat up the hill in the november event dunc. its on Nov 13/14, I think its the weekend before the national supersprint, Nov 20/21?
Sorry for the side track Ryan. I like your cage by the way.
Absolutely perfect mate. I will be up for the nationals if I have to bring a push bike. I just need to impose on someone near morgan park to store the car for a week :) send me details as soon as the other weekend is open, I'll be in and I bet Neil will be too.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
