  • Replies 49
I can get a fading transformer to light up a neon made up to size to fit in there. im not sure on price but if anyone is interested ill call around and see what i can arrange.
rembering i sell REAL neon so its 50times brighter than LED's and AEPRO autobarn stuff. problem is its glass and will need some TLC to install it in there so it doesnt break. But it would be a good effect.
Well,I am not all too familiar with the sanding of the back part yet but ,I once tried it with a Dremel and it was taking the paint off with out putting a hole through it just gotta keep it a nice and easy and be sure not to push down on it because you`ll just cut right through it FUNKMONKEY THE KNIGHT RIDER LIVES HAHA
I tryed to find out about how bright neon is and no one can tell me.
the best way to describe it is that the thicker the tube the duller the light
hungry jacks is 15mm red neon i have some 9mm red neon here. and if u turn it on in darkness u can not look at the tube for too long as it hurts your eyes.
thats the best way i can tell u how bright it is. if u put a mirror or something to reflect the neon behind it it will double in brightness (rubbs my eyes from the testing i have done this morning)
HEY PPLZ!!!! i just complete the first few stages on my badge for a 33... but i'm stuck on there lighting
i have pics on where i'm up too...
but yeah the lights i went to jay car... 30cm is just too damm short!!! it either a 'S' or a 'E' i'm missing... ahehae so yeah i don't know where to get a light...
also the hole i have made to put the light in is quite small.. just enough to fit a 5mm diameter cathode tube or sumthing of that name.. and the light it produces doesn't cover the "SKYLINE" work properly its like its too thin and yeah need some help...
One resistor per LED, any good electronics store will give you what you need, like Jaycar and then hook up to the 12 Volt park light circuit (numberplate wiring is good) and all you need to do is get some plastic or thin MDF or aluminium for a backing and drill 6mm holes to mount your LED's :wizard: Hey presto
auto trust: sounds good enough.. but ill see how good i go... but yeah its goin back on to the car first 2moro.. when i get time ill get it off again.. or when i have built my led Light show...
funky: that red translucent plastic thing i got from a sign writer they didn't have any that sticks so yeah i just cut it and slipped it in.. gonna stick it down sometime soon.. but yeah its just so i get a red lighting..
You know what would look cool.
i work at a lazercutting place and operate a lasercutter. i could cut the word SKYLINE out of 3m or 2m clear perspex rectangle so its the same size as the one of the back of all 33 or 32 skylines. then you could 2pak paint the perspex or sumthing. i dunno just an idea ? i could cut the word out to say anything the number plate of a car GODZILA anything really. but its getting late and it probabaly doesnt make sence lol.
:headspin: :headspin: :headspin: :headspin: :headspin:
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
