Stripped Rear-vision Mirror Retract Gears. Anyone Fixed/replaced Before?
The gears in my Stagea's drivers-side retractable rear-vision mirror seem to be stripped. The mirror becomes wobbly at speed, and although the mirror folds to the 'out' position, it is unable to fold back in again.
Is this hard to fix? I had a go at pulling the mirror off and having a look, but it seems pretty well stuck on. Is it a case of ordering the new cogs or electric motor assembly, or?
BUMP
Any help would be appreciated,
T
Hey mate, not sure if it's the same on the stags but on my R33 I pulled off my side mirror... there's 2 bolts inside the door holding it on, you really need to remove the door trim to get that A-sail off to expose the bolts. Then disconnect the wiring etc and the mirror assembly should just slide straight out of the door mount.
My gears were corroded stuck fast and covered in crap... was gonna be way too much work to clean/fix it so I'm just holding out until I have 'spare' money to find another one from a wreckers... I'm not fussed by it til then haha.
Thanks for the reply. I was able to purchase one on the SAU for sale section. I am hoping it is going to be fairly easy to transfer the internals of the new one into my yellow plastic housing. Has anyone tried completely dismantling a mirror and trying this before?
I'd dare say it would be *easy* enough... if you've never done anything like it before, make sure you have a check through this link:
http://www.skylinesaustralia.com/forums/R3...l&hl=mirror
There's another guide floating around somewhere in the tutorials section that explains it better but I couldn't find it.
I have the same issue with my R34 ... I thought someone might have caught the mirror walking/driving past and broke the internals ..its loose and nothing stopping it coming in all the way so it gets annoying. I might try some ghetto fix with glue/tape as it sounds like too much of a hassle to fix properly
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
