Always seems like the right thing to do at the time..... but most of us seem to regret it later on by many peoples posts. I certainly do with the much modded GTS-4 out of all the cars I have sold including my Merc CLK AMG55, 996 Turbo Porsche, Bmw 6, but I have kept my most loved, 1969 AMC Javelin and 82 Mits Starion I have passed on to my son recently for his teen son. Will be keeping the Audi TTRS for a while though!
Hi and welcome! Did you buy from Japan and import yourself or is it from elsewhere in Europe?
Well unfortunately after reviewing B-52 of the stagea manual and doing the following checks, it looks like it might be an ECU issue: Pins 25, 32, 116 and 124 have good earths (interestingly 10 and 19 don't have pins in the plug although the diagram says they should be earths Pins 80 and 109 have good battery voltage ECCS relay pins 1 and 3 have good battery voltage, and if I earth pin 2 (normally the ECU earth trigger to turn ECCS on) the relay activates and I get battery voltage at pins 67 and 72 as well. Also, when I plugged the old powerFC in it showed battery voltage on the hand controller, and started and ran the engine (poorly, since the AFM is no longer connected!) So, based on all that I'm thinking it is an internal issue in the ECU, I've contacted Link to see what they say
By funkymonkey · Posted
Should’ve been thinking about your mates while taking shits. Unacceptable. -
I’ll take the side skirts, rear bumper, and wing off you hands if it’s still available
