  • Replies 162
I had another look at the GTR yesterday. All the carbon looks amazing. Rear parcel shelf, bootlid & spoiler, bonnet/vents, engine bay, gearshift paddles, even new sport steering wheel. This Guy is the CARBON KING of South Australia!!! Very cool car.
Looking forward to hearing it under full noise out at the track. More photos Martin.........and maybe some dyno sheets?
Love to see the comparison to stock setup.
Near enough 400kw at all four wheels on our new Mainline AWD dyno at 17psi boost pressure is a nice start with a conservative tune, up from 270kw at all four stock. Thats getting close to a 50% power and matching torque improvement :D
The upgraded WR35TT turbochargers are responding nicely with excellent flat boost control, not tapering away or running out of puff at the top end like the stock pieces do. Also they will not suffer the same accelerated thrust wear and failure that the stock turbochargers do over 15psi, due to being ball bearing (no thrust bearing). So its looking nice at this stage :down:
Martin
When does the boost cut in for the new turbos? Same as the stock or a little later?
Has this affected the way the car takes off or does your car still have a little lag (if it is a ADM car) ?
Regards
Mark.
This owner could have bought a 911 or a Lambo etc, but he chose to go sick on a new R35 GTR.
Good on him. I went for a run in this car yesterday & it is awesome. Definate improvement over
my Std R35. Will look forward to going out in the country where we can stretch its legs a bit more.
Hmmm... these new turbos are looking good.
The best way of describing the response of this package is to show you the raw numbers. Attached is a dyno graph from our Mainline Chassis dyno that shows you exactly the gains vs a tune + midpipe GTR in actual percentage - the very best way of showing the comparison :)
The best way of describing the response of this package is to show you the raw numbers. Attached is a dyno graph from our Mainline Chassis dyno that shows you exactly the gains vs a tune + midpipe GTR in actual percentage - the very best way of showing the comparison :woot:
How large is the trade off lower in the rev range given the turbo's are now larger?
I did not get to go far in this car but it did not feel much different from the bottom end.
The new ball bearing core spools up faster than the std plain bearing & this car has aftermarket
dumps that replace the primary cats so less back pressure.
To really tell the difference I would have to drive this one & then mine back to back but considering
how new this car all is I dont see that happening & I wouldn't expect to.
Going for a ride in it will be fun enough.
The boost response of these turbochargers is absolutely excellent. No doubt there is a couple of hundred rpm difference in the spool - it is impossible to avoid this when going to larger turbochargers, however the short initial gearing of the GTR and its lightning fast 'on boost' GR6 transmission effectively hide any of this to the point where the car feels like it has stock bottom end response. Where it is much different is higher in the rpm where the compressors simply dont run 'out of wind' and fall of boost like the stock items do. Most importantly being ball bearing cored there are no thrust bearings to go into rapid wear and failure mode as happens with the stock GTR turbos. My belief - and I am biased on this one so forgive me - is that the WR35TT modification is superbly matched to the GTR, adding reliability with ball bearing core design, and integrating all of the factory pleasantness of a properly integrated turbocharger solution.
As for US dealers and fitters. We have a main Willall distributor in Atlanta Georgia, that being Forged Performance, and then several dealers throughout the country. Fontana Nissan Motorsport in LA, SPE are another in Socal, in fact there are many dealers you can work with directly on the East Coast of the US that have access to Willall parts and technology :D
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
