Hey guys did the hicas diagnostics on my car,
Came up with
(according to the thread in tutorial/DIY sect)
21. Vehicle speed sensor not present
I saw a guy replaced one in his R32 behind the dash, but is this where the hicas would get its reading from?
Is there another sensor somewhere the hicas reads?
also where would i get one of these to replace it?, or how can if fix it (if its repairable)
Cheers in advance
85URK
Not sure about the R33 GTR, it might be similar to the R32 GTR as I went through a few diagnostics with mine.
The R32's have a Steering wheels sensor and the brake fluid sensor, which can trigger off the HICAS Light.
What's wrong with your HICAS?
Does it only come on when the car is started up, whilst driving, turning the steering wheel..?
No i have no hicas light on, but when driving along sometimes the car will start turning by itself then straighten up and repeat again. and this is the only fault that came up on the hicas diag.
So maybe hicas system is getting a dodgey speed reading from the sensor causing it to play up.
Interesting...
Wheel alignment maybe?
Turning itself?
Meaning if you drive straight the car will start to pull towards one side..?
HICAS is design so when the car is traveling at a high speed (80km/h +) I think, the rear wheels will turn in 1 full degree in the opposite direction of the front wheels, BUT that is only when going around a large bend in the road or hammering it through a corner...
Just from speculation / guessing...
I still believe there is a Steering Wheels Sensor in the R33 GTR's.
Check your Steering Wheels Sensor, it maybe out of alignment and the HICAS computer thinks the car is turning but it is actually not at all...
Interesting...
Turning itself?
Yeah it happened when i was travelling along hway mostly at about 100km/h or over.
Yeah the car pulls to one side suddenly then straighten's up again then does it again. then it will drive normally for ages, it does it randomly.
i have really only had it do it to me a few times as i hardly drive the car for long periods of time on hways etc.
and since the hicas code came up with vehicle speed sensor i was going to start with that, but im not sure where it was located for the hicas?
I have had the car fully wheel aligned and balanced. it has coilovers, so maybe they are not set the same all round or something, wonder if that would cause it to pull to one side or affect the hicas reading?
also Where is the steering wheel sensor located?
on the steering rack somewhere?
Yeah right... Ok.
Sure, start with the Vehicle Speed Sensor.
Again I am unfamiliar where the HICAS is in the R33 but in the R32 there is a Unit in the boot, under the rear parcel shelf in between the rear speakers... Take a look and see...
The Steering wheels sensor is located behind the boss kit, inside the unit where your indicator stalk is just before the dash... Again for R32 GTR is like that, R33 should not be too different.
Can your mechanic help you out too?
Yeah right... Ok.
yeah we have been having a look at it, but havent managed to figure it out yet. il try take a look at it when i get a chance. been busy lately, and car still drives fine just except for that problem. see how i go. but if anybody can tell me exactly where sensors etc are that would be great. Thanks for your help, much appreciated.
Daz
Daz
No worries man!
If you can't sort it out just get rid of the HICAS System all together, LOL!
A lot of ppl hate it and it really is just a parking aid when you try to park your car...
All the best and let us know how you go!
:P
Isnt that where the hicas plug is for steering wheel? behind steering column covers, coz my hicas light doesnt stay on at all, and it does light up on the dash when u first turn key on when all the other lights light up.
Then it goes away after engine start up, so this would mean that the steering wheel is connected properly etc, it is a 96 with a series 3 steering wheel on it, it was like that when i got it. but this shouldnt matter much unless the sensor is stuffed, which would inturn make the hicas dashlight, light up shouldnt it?
There could be a HICAS Plug, near the Steering wheel sensor... It probably all interlinks together...
There have been a few HICAS issues with aftermarket steering wheels, but you saying you got a Nissan Series 3 wheel... It should not make too much difference as it is a Nissan Factory steering wheel.
Yeah if the HICAS light was on and stayed on after starting the car, then there will be a bit of a problem, but since it switched off for you after starting it up, there must be just a little hiccup in the system...
Also, try cleaning the Steering Wheel Sensor, that helped me, from memory my mechanic used some WD40 and then compressed air to blow dry it.
OK, here is what I did to isolate the HICAS problem that I had...
Check Powersteering fluid
Check Tires
Check Wheel Alignment
If HICAS light is still on,
Run a diagnostics
Cleaned out steering wheel sensor, it helped but the HICAS light was still coming up when I did a full lock left turn, before cleaning it out it was as soon as I turned the wheel slightly left.
Run Diagnostic again
The diagnostics was be able to read the degrees of the steering wheels sensor, when the steering wheel is at centre position, it should read 0 degrees, but it did not, it was about 30 to 50 degrees out (from memory), this was after the wheel alignment, so my mechanic re-adjusted the tire rods to take everything back to 0 degrees.
This might help to solve your problem so the car does not pull to one side...
As for the Vehicle Speed Sensor... I might have to ask my mechanic when I see him tomorrow and ask him if he can answer that one.
ok cheers.
yeah, well its all good to have the self diagnosis of the hicas system and tell you what the flashes mean, but If it comes up like the vehicle speed sensor, its good to know where to find them to be able to test them etc
That would be great if u can speak to your mechanic about it, u never know, thats what forums are for, to share the wealth of information out there.
Ok just had a quick chat to him...
Judging from your 2nd post, it sounds like a Steering Wheel Sensor / Steering Angle Sensor (Same thing).
The Vehicle Speed Sensor... I think it is near the gear box or that area... But my mechanic he has never changed one cuz that sensor hardly plays up...
Also I remember him saying that if the Vehicle Speed Sensor is playing up, your speedo will not work / read the speed you are going, so you won't know how fast you are driving.
The HICAS light can relate to a few areas in the car,
Power Steering Sensor, to check your Power Steering Fluid.
Steering Wheel Sensor / Steering Angle Sensor.
Wheel Alignment, car is not driving straight.
Just get your mechanic to re diagnose the HICAS and see how you go...
:yes:
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
