yup, sure is. get a mongoose M80 series alarm. australian standards, 3 point immobilizer circuts, black wiring harness, you can option things like window windup modules, siren and chirping when locking/unlocking, and it comes with an onboard turbo timer.
best alarm out for such a desirable car.
+1 for the m80 :D
The most important thing to remember is, do not skimp on the install!!! It doesn't matter how good your alarm is, if it's installed poorly you have just wasted your money.
Where abouts do you live? then we can recommend you a good installer.
Guido: I assume you're from Brisbane after seeing a few of your post. Give Chris Rogers a call at www.audioexpress.com.au . He'll most likely recommend autowatch for you. I got the M80 (forgot which exact model) at that time and got an autoelectrician to hoook it up for me. Everything works fine and its slightly cheaper than what Chris quoted for the Autowatch (both brands are Australian standard complied) but I'm not very happy with the detection range. If I'm 5-10metres away, it will not sense it at all (just shits when it comes to sensing range). For the amount that I'm saving (around 200), I would opt for tha Autowatch if I were to have it done again. Unless you're feeling rich, then get the gps tracking ones.
$50 alarm for a $35k car- not really.
give me a call if you want it done PROPERLY. 90% of people toss the alarm under the column and in doing that I can take teh car in 30 sec and drve off. seen PLENTY of crap jobs over hte years and have fixed quite a few more. probably the reason my name pops up so often.
currently I'm one of the few people modding the R35 electrically and those guys are quite picky on who they trust with their car.
details are in my sig.
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
