There must be some Inhuman part man part hks computer on these forums who knows about the EVC IV/pro boost controler.
I found the manual for the setup of the EVC IV pro boost controler and ill attach them here
HKS_EVC_IV_setup_manual.pdfFetching info...
Page 54 is my boost controler if a picture helps. = http://www.hksusa.com/content/pdf1580.pdf
Does any one know what the 4 dip switches do on the back with any sort of detail at all please people.
We had a try and teaching it to learn the boost curve with no luck as of yet.But my tunner wishes to know what the 4 dip switches do on the back of the unit.
IF any one at all can help me please feel free to throw up some insight on this type of boost controler.
Some pictures of my unit.
Wow no body has one of these?
Or has any idea what the switches do on the back?
I like this unit id just like to get it to work god damn it.
I have spent the last 2 days looking for infomation about this unit i found install and set up but nothing has any info on the switches on the back. I know what the po and sw switch is the the small bank of 4 has got me stuffed and im wondering if thats whats causing it to over boost past one bar after it was set up.
the dip switches on the back are to set internal or external wastegate mode
and also from memory are used as part of the hks link system which is what the rj12 socket next to it is for
so check the manual, it should show you how to set internal or external gate via the dip switches
then self learn when did mine was easy
you turn on the self learn mode
it shows -3-
then you take off in 3rd gear and redline it
then it shows -2-
do the same in 3rd gear
and then it shows -1-
do the same
then its complete and self learn is done
you take off in 3rd so it has time to learn the boost build ramp
The sw/po switch sets external vs internal gate, the dip switches are a new one to me though and I can't help.
Looked at all my notes and came up blank sorry.
I have a IV, but not the IV pro, the IV doesn't have the dip switches. Mine is LCD as well, otherwise the units are pretty much the same.
yea id love to know what the 4 dip switches do lol.
If they are wrong in any way its not going to work lol.
As for the internal gate and external gate that is the PO/SW switch on the back.The 4 dip switch is something else ,.........
Thats the problem im running into heh.
Try other forums, maybe the GTR one in the UK? They are a different knowledge source. Some one will know, just have to find them. What you have is pretty rare, ones like mine are much more common.
oh sorry yeah you are right, i was thinking it was the dip switches that did the internal external
my bad - ok so i would just leave them?
whats the issue when you do the self learn?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
