hey fellas,
just wondering if it's worth the effort and time to attempt to polish up a stocko gtr cooler so it's bare alloy instead of the black?
..and really there'd be no way to get the paint off the face of the fins anyway would there?
just wanted to ask the question, as i'm considering dropping ~1k on a pwr one, and really it's for the aesthetic of a nice shiney cooler rather than any performance gain as i know the stocko ones are pretty decent
any input would be appreciated!
https://www.sau.com.au/forums/topic/283610-polishing-stocko-32-gtr-cooler/
hey fellas,
as soon as you touch any of those fins with any force they'll bend, try and blast them they will bend. I wouldnt reccomend paint stripper as it could be too harsh but that would be the only thing i could suggest.
On the other hand, if the paint is good you could prep up the solid areas and paint it in a silver if thats the effect you want
I recommend Paint Stripper.
Got my car back from my panel beater and it was painted black so I bought a tin of Paint Stripper and took the front mount intercooler back to the bare metal like how my car came from Japan.
Just heavily mask up your front bar or better, take your front bar off and get a cheap paint brush and start applying the Paint Stripper and watch the paint it come off.
There is paint stripper for plastic and metal surfaces (different strengths) If your worried, get the one for plastic, but metal should be fine as that was the one I used.
Intercoolers work best unpainted.
cheers boys, pretty much the info i wanted
(oo)skyline(oo) is the cooler in your avatar just the stocko one? cos that's the look i'm chasing
LOL!
Nah it just a pic on the internet which I Photoshopped.
I will take a pic of my FMIC after the paintstripper, post it up tonight and show you.
It turned out very nice too.
Or I can PM you.
im keen to see your cool to man
if you chuck it up on this thread it'd be awesome
the forum won't let me use PMs until i've posted some more
Yeah no worries!
Here is what it looks like after the Paint Strip.
So much better!
Some ppl liked the black painted intercooler and said it looked tuff / sleeper, but I could not resist a bare metal cooler hehe!!
oven cleaner works good too.
only problem is that oven cleaner is caustic and shouldnt be used on aluminium. if you can be sure you can clean it sufficiently it wont harm it for small periods - works great for cleaning off burn oil from under cam covers though :)
i done mine myself with just spray paint.. just painted straight over the black lol
here take a look at the pic, i thought it came out pretty awesome as everyone thinks its an after market one lol.
if your going to paint strip it, after you have appllied th stuff, put some plastic sheeting over it for the recomended time it to be left on, this helps dramatically in removing the paint.. ( think it just keeps all the solvent in and stops oxygen gettin in) if ya didnt already know ;)
really?
would it not reduce it's effectiveness by having 2 layers of paint covering it or am i just being a baby??
i had that same thought and a few mates also made the same comment on having 2 layers of paint on it would clog up the fins. paint stripper in a can worked great and all i did was sprayed it on left it for a bit and hosed it of. done that a few times then just got some polish for the tanks. the pic in my last post isnt that great doesnt show how good it came up.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
