Hey guys!
I have an R32 GTS4 - Yes.. I know.. strange choice for drifter.. dont worry.. ATTESSA is going to be stripped out soon.
Now, I need more lock on the thing! I find myself hitting full lock very often and not getting that sideways.
I have a couple of questions,
1) Is the GTS4 and GTST steering rack different? I find that my GTS4 has the turning circle of a truck. Would it be worth tracking down a GTST steering rack?
2) What steering racks have poeple swapped with the R32 rack for more lock?
3) What products (steering rack spacers, tie rod ends, lower control arms etc.) have people used to gain more lock? Any feedback? Whats good? Whats crap? Prices? Where can I find them from?
Any other feedback on what people have done for more lock would be greatly appreciated!
Thanks guys! :)
https://www.sau.com.au/forums/topic/283627-need-more-lock-on-r32/
it's nothing to do with rack. it's to do with the fact that your car is 4wd and as such has front driveshafts. imagine the driveshaft angles!! that is why you cannot get much steering lock on any awd car, front driveshafts.
the only way out is remove the drive shafts, weld up sump etc. but it's a shitload of hassle. would be far easier to just start with a 2wd car. plus with your current car you still ahve extra weight of transfer case and any other awd associated bits.
Thats all well and good.
ATTESSA will be stripped soon enough.. rip out the front diff and use a RWD sump.
But once thats happened.. what can i do for more lock?
well first it's good to know exactly what's restricting lock. the steering rack only moves so far, the knuckles have a stopper which corresponds with a little tab on the LCA which stops lock, the tyres can foul against the chassis rails, and the knuckles start binding past a certain amount of steering angle.
so first things first, u can put some steering rack spacers which allow the rack to move further. from here the knuckles will start to stop on the LCA's, so u will need to modify either the tab on the LCA, or the stopper on the knuckles. around the same time u will have issues with tyres fouling on the chassis rails depending on what tyres/wheels ur running. if the tyre is big enough and offset is high enough u will have issues. for example i scrub with 5mm rack spacers, 17x9 +24's with 235/45's. few things u can do to stop this, either go lower profile, thinner tyre, or lower offset. u can also go longer LCA's like R33 ones which push the wheel out a bit further.
from there u will start experiencing binding issues on the standard knuckles, so then the next step is new knuckles or cut and shut ones. this can change things like ackerman angle, length of the knuckle, shape etc etc, which not only provides more lock, it reduces binding and changes the feel in the steering, as well as the turn ratio.
  • Like 1
Interesting that you scrub with that offset stewy?
I have installed the 5mm rack spacers in my 32 gtst and the increased lock is quite massive.
I am running R33 GTR wheels 17x9 +30 with 235/45/17 tyres and it doesnt scrub on the rails. I definitely couldn't get more lock as the wheels nearly hit the castor arms at the front. I have noticed that the tabs on the LCA are now doing their job and stopping it there. That's a good thing!
My only problem now is that my solid brake lines on the caliper are now pushed onto the rim at full lock. Not a good thing! I'm investigating braided lines now.
yeh, i should note however i had extra lock due to the tabs on my LCA's being dented in a good 4mm from hitting the lock stops drifting over time. i keep forgetting about that haha. when i put R33 LCA's in with undented tabs, they gave me a few cm of clearance from the rails. but they did pull the wheel out a bit due to being longer.
and it was very minor scrubbing, in fact i didnt even notice it drifting on full lock, it was only when doing a u-turn or something at full lock on uneven ground (up a curb or something) it was just touching the rails.
This is a stupid question..
But what are steering rack spacers?
What do they look like?
How do they work?
Are they similr to some sort of shim?
How do you install them?
http://www.gktech.com.au/products/?ID=160
I have wondered about installing steering rack spacers on my car. The thing that I am not sure about is that if these spacers allow your wheels to travel further, wouldnt you run into problems with the wheels rubbing on the front sway bar and castor rods? My wheels are already rubbing the sway bar and castor rods at full lock. I have 17" wheels with 235's, car has been lowered slightly.
Thanks for that Nisskid. I understand how spacers allow the wheels to travel further, but am I still right to be concerned about extra rubbing as a result? See my attached picture (I apologise in advance for how crap it is).
With the further travel of the wheel, wont it now rub on the castor rod + front sway bar (the pink bits on my pic)? As my wheels already do this when at lock I am wondering if spacers will even do anything for me. IE: having extra travel isnt go to do anything if the wheel is already stopped by other suspension bits.
Sorry for stealing thread a little but hopefully we can all benefit from this :D
My R32gtst has s14 rack (more lock) and spacers (more lock again) and does not rub on anything. 6.5 caster, 3 deg toe out, 2inch lower than standard ride height. I run standard wheels with 205/50 tyres. hope it helps a bit. :)
I noticed the GTR racks a re totally different to GTST. it was as if one side had a different knuckle geometry to the other. one tie rod was longer than the other..also you can buy AM tie rods with integrated spacer and comes with thinner spacers (washers) to give you max lock.
Cheers
  • 3 weeks later...
So as a temp measure for someone with 33GTR wheels and tie rod spacers whos wheels are hitting something on full lock, (235/45/17 KU36, sounds like rim hitting LCA or chassis), could I fit a spacer on the front until i can get knuckles? are knuckles a proper fix for this and more lock?
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
