I am tired and not thinking very well but if you wheel is hitting something now (like LCA or chassis) knuckles will not solve the problem as your rim is already hitting with the limited lock. You need to figure out what and where is hitting so you can fix it.
If it is just the knuckle knob thing hitting LCA lock stop then yes, modifying knuckles and/or LCA will get you more lock but then you may run into other issues of hitting depending on offset, tyre etc.
My R33 knuckles are getting modified today by Nigel. Should have them in soon but the next drift day isn't till December for me to try them out :P
Edit. Forgot to mention Nigel also supplies spacers that help with binding issues. They aren't cheap but look like a must when wanting that extra lock.
Edited by gunmetalgrey
with 17x9 +30 and 235/45 and spacers i can almost guarentee u its on the chassis rails. not much u can do but go lower offset, smaller tyre, or longer LCA's (R33 etc).
nigels knuckles will lower the ackerman, as well as give u more lock, so to even consider getting the most lock out of those ur gonna have to go 17x9 +10ish
going to try and modify my current set, well the rears at least, making them 17x10 +12, which will allow me to run 25mm spacers up front to make the fronts 17x9 -1, this will give me tonnes of clearance up front.
looks like nigels knuckles and new rims. Stagea for sale BTW :)
Is it going to be doing damage to the rails?
nah not really, it's ur tyre rubbing, might make a bit of a mess of the thin metal at the seams that comes off the rails, but nothing structural.
Running 17x9 35+ ofset, 225 40 tyres, and rubs on chassis at full lock.
Thinking about r33 LCA's and lock spacers, or even just R33 LCA's.
But s14 rack sounds like a fun job!
add some 25mm spacers and it'll be gravy
i got r33 LCA's tie rods with extra lock 7 deg castor 3 deg camber bumper steer adj running 17 x 9 +17 P1's with 235 /45 ku36's on front and got no probs with hitting anything and decent lock
pic below but obv not full lock got one somewhere will put up if i find
Edited by bcozican
This is a picture of one installed.
All the info you need about them is in this thread...amongst the 40 or so pages lol
http://nissansilvia.com/forums/index.php?s...823&st=1080
Hope you like reading.
Guessing that is the knuckle thread? Currently reading that, about 30% of the way through... up too post 521
are all r33 LCA's the same? i.e turbo/ non-turbo, coupe/sedan? how much difference do they make compared to standard ones? also to put the s14 steering rack in was there any modification required?
cheers
Sedan to coupe defiantly are and I am confident non-turbo/turbo would be as well. Off the top of my head I think they add around a degree or so. Its a cheap alternative to camber arms to gain that extra bit in the front.
I've heard it's more like 3 deg camber gain
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
