S13, 180sx, Parts, Engine, Gearbox, Nismo, Bottom Ends, Heads, Manifolds, Exhaust, Turbo, Gtr Rims, 5 Stud, Front Mount, Apexi
PICS UP SOON
SR20 BOTTOM ENDS MUST GO Taking up space!
All going cheap need quick sale!
SR20DET Engine $1500
Fresh imported engine from just jap with receipt 2 months old
Gearbox with slave cylinder and line and shifter $600
Apexi turbo timer with wiring harness $100
Apexi AVCR boost controller all wiring $600
Front mount intercooler kit with piping and blow off valve $200
3" Straight through exhaust turbo back $200
Mandrel bent, high flow cat and heat wrap
s13 rear brake calipers $100
s13 skyline front brake calipers made to fit s13 $150
Nismo braided clutch line $100
Tail shaft $100
Five stud conversion kit $500
ICHIBARN from USA bolt on with genuine new wheel bearings
Nismo braided brake lines $200
R32 GTR wheels $500
With tires
REAR DIFF CV SHAFTS $50
2x sr20 red top standard turbos $100 each
2x sr20 red top heads "top end" with cams and bits $300 each
2x sr20 bottom ends $300
One seized from fuel in oil
One turns detonated piston 2
MUST GO
2x sr20 exhaust manifolds $80
2x sr20 intake manifolds $80
ECU red top standard $100
ECU red top nistune! $300
Can retune!
Tuned for 300HP fmic, disco spud and greddy easy cams
Will need retune depending on your application
PICK UP ONLY
PREFER TXT OR PM 0423428670
Calipers only? No rotors? How are they made to fit an S13?
As listed calipers only
Re drilled and tapped to bolt straight on!
FFS! Yeah thats nice
BUT im trying to sell stuff not fkn, have a debate about whats what!
So PLEASE keep comments to self
  • 1 month later...
Hey mate,
Is the engine still available? Any idea on the kms on it please?
Cheers
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
