2dabass Posted August 16, 2009 Share Posted August 16, 2009 anyone know where do get a set? or has some lying around? stock or after market dont mind... pm me asap Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/ Share on other sites More sharing options...
syfon Posted August 17, 2009 Share Posted August 17, 2009 What you want stock rb25 cams for? There was a set of 256/256 tomei cams for sale in the wa for sal section about a month ago. Maybe they are still for sale? Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4771780 Share on other sites More sharing options...
2dabass Posted August 17, 2009 Author Share Posted August 17, 2009 saw them... nah i just want stock ones preferably..... anyone know where to get them? Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4771856 Share on other sites More sharing options...
bubba Posted August 17, 2009 Share Posted August 17, 2009 Consolidated workshop thread? Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4771861 Share on other sites More sharing options...
Marco-R34GTT Posted August 17, 2009 Share Posted August 17, 2009 PM sent mate.. I've just a cam installation.. Either way, the rocker has to come off, and you've got to get the cams reshimmed, even if you are swapping stock cams for stock cams.. I've got some mild type A cams for sale if you're keen. As said though, refer to your PM. Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4772336 Share on other sites More sharing options...
syfon Posted August 17, 2009 Share Posted August 17, 2009 Mild type A cams? What's the difference between those and the stock S2 R33 RB25DET cams? Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4772714 Share on other sites More sharing options...
Marco-R34GTT Posted August 17, 2009 Share Posted August 17, 2009 I've got the TYPE A (aka stage 1) Poncams: ECR33 Series 2 (RB25DET) - Duration: IN, EX 256 Lift: IN,EX 8.5mm Lift is same as stock but there is a bit more duration which gives you a bit more breathing/grunt across most of the rev range. Not too sure what stock is, but I had to get another set for my R34 and I ended up getting 260's instead, which is what you'd call stage 2 (or type B). Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4772793 Share on other sites More sharing options...
r31gtsxjspec Posted August 17, 2009 Share Posted August 17, 2009 I've got a semi complete rb25 if u want the cams out of it 150.00 for the whole motor Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4773017 Share on other sites More sharing options...
Swiper the Fox Posted August 17, 2009 Share Posted August 17, 2009 (edited) anyone know where do get a set? or has some lying around? stock or after market dont mind... pm me asap I have a pair if you want them...stockers that is. Edited August 17, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4773040 Share on other sites More sharing options...
bubba Posted August 18, 2009 Share Posted August 18, 2009 PM sent mate..I've just a cam installation.. Either way, the rocker has to come off, and you've got to get the cams reshimmed, even if you are swapping stock cams for stock cams.. I've got some mild type A cams for sale if you're keen. As said though, refer to your PM. Marco, Neos require shimming due to the solid lifters. Normal 25s have hydraulic lifters which take up their own clearance. Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4773892 Share on other sites More sharing options...
Marco-R34GTT Posted August 18, 2009 Share Posted August 18, 2009 Marco, Neos require shimming due to the solid lifters.Normal 25s have hydraulic lifters which take up their own clearance. Doh! Indeed they do, completely forgot about the lifters. What he said! Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4774232 Share on other sites More sharing options...
2dabass Posted August 20, 2009 Author Share Posted August 20, 2009 can someone please pm me with a price and the mobile number so i can contact them Link to comment https://www.sau.com.au/forums/topic/283685-rb25det-cams/#findComment-4778929 Share on other sites More sharing options...
