Seller wants a fair bit more than that.
Car is virtually showroom condition
I am no expert on R31's but these machines seem to be up to $15k depending on condition. It has low kms and if it is in showroom condition it would be around that mark. Then again, in this current used car market who knows?
https://www.sau.com.au/forums/topic/283699-whats-it-worth/#findComment-4775611
well i know of one with a 2JZ, and one with e fully kitted RB26dett... if its either of them.... buy it.
No nothing like that mate.
For a classic that will appreciate you need something stock that hasn't been mucked around with.
This one I just bought is stock as a rock
I told the owner if he ever was to sell the car could he let me have first refusal.
So 17 years later he rang me :down:
It's a one owner car with log books and only 100,000 kms
But that something extra for me was the fact that it is numbered 001
https://www.sau.com.au/forums/topic/283699-whats-it-worth/#findComment-4779500
I have seen a GTS1 with a factoryish turbo kit on it go for 7.5k, was in great condition, if it had an IRS rear I would of considered it myself
Is that VL-turbo factoryish, or rare-as SVD test-mule factoryish?
(And an Aussie GTS will never have IRS)
So 17 years later he rang me :(
That a pretty special machine, and deserves to be treated with care!
https://www.sau.com.au/forums/topic/283699-whats-it-worth/#findComment-4782995
  • 3 weeks later...
Thanks for the comments guys
Finally got home from Canada/Alaska after a months holiday.
Car was sitting in my garage when I saw it for the first time.
OMG :)
I'm in love...this car is just like it rolled off the showroom floor.
Next day when I drove her I realised she was not just a pretty face as she drove like new as well.
Car came with 3 sets of logbooks as it was serviced by time not kms so the original logbook was fully stamped by 30,000kms.
Opening the bonnet was a pleasant surprise too...yes the engine bay is as clean as it looks
Edited by R34
https://www.sau.com.au/forums/topic/283699-whats-it-worth/#findComment-4841412
in 10 years it becomes officially vintage, theres only like 130-150 GTS2s left and its #1...
I got a surprise for you "DriftGTS" vintage stopped in the 1920's and anything after that will never be a vintage car, but there will always be collectables like this.
Great buy Chris, if you can afford to hold on to it for the rest of your life it will be of grand value.
Cheers, D
https://www.sau.com.au/forums/topic/283699-whats-it-worth/#findComment-4841501
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
