How do you find the PPG. I want to buy a box for my car, so need an SR20DET gearset but i keep reading about horror stories about PPG's after sales support. Last thing i want is to spend the money and get worse reliability.
Really interested who the best person to deal with who supports PPG. Sometimes the manufacturer is terrible to deal with and you just need to find the vendor who really supports that manufacturer
  • Replies 41
Posted Images
I use many Race gear sets and recommend PPG only in the R33 GTS/GTR gearbox only, SR20 PPG IS a weak Toy, They dont even take what the stock SR box can. I have seen 300rwhp kill them after a very short time. Modena is the best for most cars.
Our S14A IPRA Racecar Uses the RB25 box with the Kiwi made adapter kit.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
