Well, hot on the heels of the first Dutton Rally event, its been confirmed that the next one will be on the June long weekend next year, 4-6 June.
Just thought I'd post up to guage interest from the club in joining in. For 2 drivers with top line cheater tyres you should allow up to $2k each for the weekend.
The earlier you start preparing, saving and approaching sponsors the easier this can be :)
So, who's interested? If there are more than about 5 entries I'll loby those guys for a 6 cylinder Tubro class so we can beat up XR6Ts in peace :)
Updated, interested expressed by:
Duncan
Dan
Carlo
Dominic
GSR13s
Fatz
B-man
Red900ss
OzGTR97v and Zane
Gonad Man
https://www.sau.com.au/forums/topic/28372-dutton-rally-2004/
  • Replies 83
Yes you only need a level 2s licence:
I dont think Id go for sticky tyres next year, Im going for better tread for the skid pan stuff (Save $1,600)
The best way to get sponsors is to contact companies that you do business with. Dont expect someone that does not know you to give you money, esp not speed shops tyre co. etc. I prepare a package with pictures of my car and send them to people in charge of Companies that I know.
In return for their tax deductible donation they get framed pictures of *their sponsored race car*. I ask for $1,100 per sponsor, which covers them for all the events I do each year. I can normally get $5,500 to $7,700.
I also split the entry fee and accomodation down the middle as after all they are using my car, wheels, tyres, petrol, consumables etc. Strangely enough my co-drivers always seem to be able to wring more out of my car than I can. (Other peoples cars go faster syndrome)
https://www.sau.com.au/forums/topic/28372-dutton-rally-2004/#findComment-590055
Hey guys!
Fatz is already frothing at the mouth over next years Dutton. The enthusiasm is infectious! I think I've caught it!
I've just gotta find some people stupid enough to sponsor me and someone stupid enough to co-drive a bloody WRX. Any takers..........................thought not! :bahaha:
Seriously though I'd love to be there in 2004. I'm getting plenty of practice in on the skid pan!
Cheers,
Ben
https://www.sau.com.au/forums/topic/28372-dutton-rally-2004/#findComment-592149
Duncan,
That is the wrong form... it says 4th-6th June 2003
Can you please send the right one?
LOL
Dan.
Nads,
If you need a co driver then I might be stupid enough... never drivin a hyundai though... :confused:
Dan.
https://www.sau.com.au/forums/topic/28372-dutton-rally-2004/#findComment-592202
Hey Guys.
Good news, the organisers have confirmed we there will be a RWD 6cyl tubro class as long as ther are 6 entries ;)
On the other hand, I guess I'll have to enter my shiney new race GTR in class A :headspin:
Oh, and interest list updated in first post :)
https://www.sau.com.au/forums/topic/28372-dutton-rally-2004/#findComment-593165
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
