  • Replies 83
Slight error - Vic is 6th to 8th August 2004!
You may well be correct.
The Friday/Sat/Sun is the 6th-8th - so Anthony probably got it wrong - Apologies to anyone misled..
When I spoke to Anthony last night, he told me those dates, but said double check with Sam on the Vic dates.
I won't call Sam at the moment as he is going to be hell busy this weekend with The Porsche Mt Buller Sprint..
Good news, I just spoke to Anthony and the price for this year is $2200 for 2 drivers. Events look the same as last year which means a great variety including the spectacular Sutton Road Hillclimb course ;)
And, we can still get a 6 cyl tubro rwd class if we get 6 entries....hint hint.
Entry forms and sup regs are here:
http://www.duttonrally.com/NSWDefault.html
Forms In:
Oz and Zane - R33 GTR
Definate but no forms yet:
Duncan and Fatz - R32 GTR
Kel and Majanal - W34 Stagea
Hopeful!
Carlo and Daz - R33 GTST
GTR032, codriver? - R32 GTR
Bman?
Red900ss?
Gonads?
Dominic?
haw001?
Why don't some of you hopefuls get together and turn into definates. At only $2200 to enter, including accomodation, petrol etc you should get out for under $1500 each for a TOP weekend :)
Yes, I got my form and deposit in.
$1,100 (of O.P.M.) well spent.
And a big thank you to my Major Sponsors
Pacific pool cleaning,
CHU Insurance
AA Accomplished Pest Control
Powertek electrical
Always on Top roofing
and the lesser sponsors (cheapskates who wont pay for a full year in advance)
Forms In:
Hopeful!
Bman?
Red900ss?
Gonads?
Dominic?
haw001?
Why don't some of you hopefuls get together and turn into definates.  At only $2200 to enter, including accomodation, petrol etc you should get out for under $1500 each for a TOP weekend ;)
Hey,
Very keen to enter - Have Co driver aswell, John (F3 driver) ;)
Just need to sort out sponsors and cash , going to Japan in January left me with empty pockets, although I did get some decent car parts!
Also, whats the deal with 6cyclinder RWD turbo class, R32 GTR's are ok even though 4WD?
cheers
Jono
Hey Jono, GTRs will be competing in (dominating ;)) class A, 4wd turbo.
The new class we were trying to get hold of was RWD turbo to give the GTSTs a chance of class victory.
Good to hear you're in too ;)
OK cool, thanx
'Dominating' class huh? hahaha
I better get some track/skidpan practice in, only done 1 track day in GTR. Was the PULSAR GTIR day at Wakefield last september I think. You were there too..didn't get past me though ;)
yeah, I think that skidpan practice is what I need most....we did *very* poorly last year in the wet. The track sections are pretty straight forward as long as you've been there before
and keep your hands off your fuses biatches ;)
Yeah, for sure spectating should be great, it will be at Eastern Creek all day on the long weekend Monday....track, skidpan and figure 8 with all sorts of exotic cars being chopped by skylines :worship:
Dan......if ya can't beat em....join em :cheers:
  • 2 months later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
