  • Replies 83
Slight error - Vic is 6th to 8th August 2004!
You may well be correct.
The Friday/Sat/Sun is the 6th-8th - so Anthony probably got it wrong - Apologies to anyone misled..
When I spoke to Anthony last night, he told me those dates, but said double check with Sam on the Vic dates.
I won't call Sam at the moment as he is going to be hell busy this weekend with The Porsche Mt Buller Sprint..
Good news, I just spoke to Anthony and the price for this year is $2200 for 2 drivers. Events look the same as last year which means a great variety including the spectacular Sutton Road Hillclimb course ;)
And, we can still get a 6 cyl tubro rwd class if we get 6 entries....hint hint.
Entry forms and sup regs are here:
http://www.duttonrally.com/NSWDefault.html
Forms In:
Oz and Zane - R33 GTR
Definate but no forms yet:
Duncan and Fatz - R32 GTR
Kel and Majanal - W34 Stagea
Hopeful!
Carlo and Daz - R33 GTST
GTR032, codriver? - R32 GTR
Bman?
Red900ss?
Gonads?
Dominic?
haw001?
Why don't some of you hopefuls get together and turn into definates. At only $2200 to enter, including accomodation, petrol etc you should get out for under $1500 each for a TOP weekend :)
Yes, I got my form and deposit in.
$1,100 (of O.P.M.) well spent.
And a big thank you to my Major Sponsors
Pacific pool cleaning,
CHU Insurance
AA Accomplished Pest Control
Powertek electrical
Always on Top roofing
and the lesser sponsors (cheapskates who wont pay for a full year in advance)
Forms In:
Hopeful!
Bman?
Red900ss?
Gonads?
Dominic?
haw001?
Why don't some of you hopefuls get together and turn into definates.  At only $2200 to enter, including accomodation, petrol etc you should get out for under $1500 each for a TOP weekend ;)
Hey,
Very keen to enter - Have Co driver aswell, John (F3 driver) ;)
Just need to sort out sponsors and cash , going to Japan in January left me with empty pockets, although I did get some decent car parts!
Also, whats the deal with 6cyclinder RWD turbo class, R32 GTR's are ok even though 4WD?
cheers
Jono
Hey Jono, GTRs will be competing in (dominating ;)) class A, 4wd turbo.
The new class we were trying to get hold of was RWD turbo to give the GTSTs a chance of class victory.
Good to hear you're in too ;)
OK cool, thanx
'Dominating' class huh? hahaha
I better get some track/skidpan practice in, only done 1 track day in GTR. Was the PULSAR GTIR day at Wakefield last september I think. You were there too..didn't get past me though ;)
yeah, I think that skidpan practice is what I need most....we did *very* poorly last year in the wet. The track sections are pretty straight forward as long as you've been there before
and keep your hands off your fuses biatches ;)
Yeah, for sure spectating should be great, it will be at Eastern Creek all day on the long weekend Monday....track, skidpan and figure 8 with all sorts of exotic cars being chopped by skylines :worship:
Dan......if ya can't beat em....join em :cheers:
  • 2 months later...
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
