heya guys,
just want to know.. im thinking about taking my car to wakefield and i know that the stock r33 gtr turbos being cast wheels are very shit and tend to go when pushed..
my question is, what is a safe amount of boost to run 10 psi ??
its a stock engine.. just filters cat back exhaust apexi PFC. everything else is stock.
thanks in advance for your help. i just dont want to do any damage to my car.
thanks chris.
https://www.sau.com.au/forums/topic/283780-need-help-from-you-skyline-gods/
The turbine wheels are ceramic and yeah they go pop. Mine did at 13psi with a very conservative 11.5 AFR tune, at Wakefield. Fortunately i could drive home - i hear to tow back to sydney is ~$800.
Anyways, the more boost the more risk, and if you're unlucky the motor can be destroyed when they go. So yeah, just run them at stock boost, and try and get some steel wheeled replacements as soon as you can. FWIW the stockers are supposed to be rebuilt every 100,000kms.
i have a high flow cat. 14.5 psi is what it is running.
this is going to be my first taking it on the track so i wont be going too crazy. i think ill just run it at 10 psi. and let it cool down every 15 mins ( as its 15 mins on the track at a time )
n1 oil pump and acl race bearings have been fitted also.
so yous are saying 10 psi will be safe ?
there is no way to guarantee what is safe and what isn't. I have run one R32 GTR on stock turbos at 14psi at lots of track days without problems. on the other side I know of plenty that died on their first track day at stock boost.
it's a risk. you might be fine, you might not. there is not way to tell. sure running less boost should improve your chances so keep it to 10 or 12psi would be a good idea. an oil cooler is a good idea too on any GTR going to the track and a proper oil pressure and oil temp gauge is handy too as the stock ones are pretty hopeless. keep the revs sensible (no need to rev a mild GTR past 7500 or even 7,000 really on track) and keep an eye on temps and you SHOULD be fine. no promises though.....
ahh sweet thanks for the info... like i said its my first time on the track i wont be going to crazy as i will only be just learning the limits of the car. ill run about 12 psi.. and as i have no oil cooler or anything. i will just take it easy and enjoy myself.
thanks for all the info guys ( just cross your fingers for me ) lol...
im going to wakefield on the 29th i think.. the end of this month, so ill let use know how i go.
thanks again for the help !! :cool:
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
