Originally posted by Greg
Lost this thread amongst others when server went down.
When: this saturday 22nd November, early start (9:00 am???)
Where: BMT Motorsport: 5 Abbott Street, Fairfield. PH 9497 5600
dr_drift: what time should we arrive on saturday?
if you didn't notice, its the 25th of nov now... sure you got the date right or did you miss your own event? :)
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-589208
Originally posted by funkymonkey
if you didn't notice, its the 25th of nov now... sure you got the date right or did you miss your own event? :D
lol :Oops: i was confused, brain has entered holiday mode :)
DYNO DAY IS saturday 29th, NOT 22nd. That date was in my mind because that was date originally planned! :Oops:
funky you should come along :(
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-589702
Can't believe you guys all got there so early, I was the last to rock up, but then again I was working till 3am this morning ;)
ok i'm not gonna list what my car made, but i'm sure someone else will post up the results. lets say it wasn't very much, as expected i guess :)
But by 10:30 this morning the weather reports already had the temps at 30degrees.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592945
I can post up a scan of the power graph with the 5 cars on it if everyone dont mind? Was good to see a few more people off the forums. As for results, i got what i expected ;), just a little less than gregs car. I thought the power ratings would have been up a little more tho.
EDIT/ADD: There was a crash near the end of the eastern, Commie rearended a commie. sorta slowed our escape from the heat.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592964
Hey Cortide, go for it. I think ur car is running well Cortide.
I didn't realise you took the eastern, I was on it too but luckily i get off on Doncaster Rd exit, just before it started to pile up. Was trying to see what had happened and could only see that some car had obviously crashed.
Next time i'll put a pod on and see if it makes any difference.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592969
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
