Originally posted by Greg
Lost this thread amongst others when server went down.
When: this saturday 22nd November, early start (9:00 am???)
Where: BMT Motorsport: 5 Abbott Street, Fairfield. PH 9497 5600
dr_drift: what time should we arrive on saturday?
if you didn't notice, its the 25th of nov now... sure you got the date right or did you miss your own event? :)
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-589208
Originally posted by funkymonkey
if you didn't notice, its the 25th of nov now... sure you got the date right or did you miss your own event? :D
lol :Oops: i was confused, brain has entered holiday mode :)
DYNO DAY IS saturday 29th, NOT 22nd. That date was in my mind because that was date originally planned! :Oops:
funky you should come along :(
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-589702
Can't believe you guys all got there so early, I was the last to rock up, but then again I was working till 3am this morning ;)
ok i'm not gonna list what my car made, but i'm sure someone else will post up the results. lets say it wasn't very much, as expected i guess :)
But by 10:30 this morning the weather reports already had the temps at 30degrees.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592945
I can post up a scan of the power graph with the 5 cars on it if everyone dont mind? Was good to see a few more people off the forums. As for results, i got what i expected ;), just a little less than gregs car. I thought the power ratings would have been up a little more tho.
EDIT/ADD: There was a crash near the end of the eastern, Commie rearended a commie. sorta slowed our escape from the heat.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592964
Hey Cortide, go for it. I think ur car is running well Cortide.
I didn't realise you took the eastern, I was on it too but luckily i get off on Doncaster Rd exit, just before it started to pile up. Was trying to see what had happened and could only see that some car had obviously crashed.
Next time i'll put a pod on and see if it makes any difference.
https://www.sau.com.au/forums/topic/28381-vic-na-dyno-day/#findComment-592969
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
