sorry guys i came early this morning at around 8:30 but didnt introduce myself as i was on delivery and had to go to croydon
just went past to get soemthing from sam and had the pleasure of seeing the 1600
hehe go the 1600 ;)
What I found most interesting was the power curve of my car compared to say cortide's car, which is dead stock. This fairly linear curve is no doubt due to the extractors - _turtle_'s car with the same extractors as mine (Coby) showed a similar curve. To actually see proof that spending money on my car gives real results is pretty satisfying - it's not all just for noise making purposes :)
All dyno results were taken in 4th gear (except for one of funkys runs).
What I found most interesting was the power curve of my car compared to say cortide's car, which is dead stock. This fairly linear curve is no doubt due to the extractors - _turtle_'s car with the same extractors as mine (Coby) showed a similar curve. To actually see proof that spending money on my car gives real results is pretty satisfying - it's not all just for noise making purposes ;)
Looking at my dyno sheet attached, is my car running too lean or too rich??? Yes i know i asked this about 3 times today already but i forgot!
Yours was too rich i think. i cant remember i think richer was lower.
It was good to see the comparisons.
Power graph
I hope you guys dont mind, this is the graph of the 5 cars for power. So you can see what greg means.
Mine (Blue) - Stock
Gregs and _turtle_ (red colors) - not so stock
from memory Dr_drift said that he tunes turbo cars to 0.8 but n/a's can run a little leaner, I think 0.9 was acceptable??
I don't like tuning turbo's leaner than 0.82 on full boost, but NA cars are under less stress and can run well a little leaner.... I would think 0.9 would be a bit lean for good power, but basically tune the N/A's wherever they make best power between 0.82 and 0.88
Doc.
Hey doc, would advancing the timing a few degrees make any difference?
Ever since I had my timing belt replaced the car has not been the same, wonder if that could effect anything.
depends where it's at now??
Not sure where the timings at now as i dunno how to rig up the timing gun to it as theres not spark plug leads, i remember someone else told me some other method but dunno.
Anyways its a good indication of how our cars are running, and for those totally stock cars they can compare again next time they have put an exhaust or something on.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
