Need Cams License And Sau Vic Membership!
Hey guyz, Im a little stuck here, just came to know that there is a drift day on the 5th of september which i would like to participate in and for that i need a Cams license[ Not sure which one L2S or L2NS], i want the cams license that i can use for track days also like circuits, Where can i download the Cams form from??
And how many days does it take to get the membership.. And i even need to take SAU Vic membership as it is affiliated with cams and i know that it can take upto 15 days to get my SAU Vic membership, but can i like pay for the SAU membership and get my cams license in few days??
Any help would be appreciated... Thnx Guyz!!
Why do you ask if you get them in a few days - You have a few weeks, you have time to get both before September 5.
I recommend sending both applications off ASAFP though to make sure you have them :D
Go here and download a CAMS Level 2 Speed (L2S) form and send it off right away - http://cams.com.au/en/Development/Get%20In...ce%20Types.aspx
SAU Vic Membership Thread is a sticky at the top of the Victorian section - do this right away as well.
Hope this helps
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
